cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
6
Respuestas
Connection failure between Nexus 7700 and Catalyst 3560
Greetings Cisco community.
I am writing to you on this occasion to request assistance in the following case:
I have been trying to connect a Nexus 7700 (NOX-OS version n7700-s2-dk9.8.4.2.bin) with a Catalyst 3750E switch (IOS 12.2(35r)SE1) and a Catalyst 3560 (IOS 12.2(44)SE5) .
Both backbone connections are fiber optic with 1Gb Gbic.
The problem is that when connecting the ports at the Nexus end they are active and connected but at the Catalyst end the ports are not seen connected.
I already checked the Nexus ports against other computers and they work fine, I also checked the Catalyst ports against other computers and they still connect and work fine.
Is it possible that I am missing some specific configuration in these computers to be able to connect them with each other with a trunk connection?
1 SOLUCIÓN ACEPTADA
Soluciones aceptadas
Hola,
Puedes intentar lo siguiente:
Sea dejar una autonegociación automatica o configurar la speed y el duplex en ambos lados
Nexus 7700:
interface Ethernet1/16
switchport
switchport mode trunk
switchport trunk allowed vlan 30
no shutdown
Catalyst 3560:
interface GigabitEthernet0/2
switchport nonegotiate
end
o
Nexus 7700:
switchport
speed 1000
duplex full
no shutdown
Catalyst 3560:
speed 1000
duplex full
end
Dejame sabe los resultados,
saludos
Leomardo
Ver la solución en mensaje original publicado
6 RESPUESTAS 6
Hola  telecomunicaciones2
I am not sure of clearly understand the problem.
   Nexus ----3560
     |--------3750
- Could you please clarify on this?
- Are you concern about access ports or trunk ports connectivity?
- You should attach the interface configuration to better understand the problem and better guide you.
Saludos
Leonardo
Saludos Leonardo.
Estoy conectando un Nexus 7700 con un switch Catalyst 3560, mediante una conexión troncal con puertos de fibra óptica.
En el Nexus observo el puerto conectado, pero en el switch Catalyst el puerto no levanta. Ya verifique el funcionamiento del puerto del Catalyst, conectando con otro switch Catalyst por el mismo puerto troncal y funciona sin problema.
Esta es la configuracion de los puertos:
Nexus 7700:
switchport
speed 1000
duplex full
no shutdown
Catalyst 3560:
end
Saludos  @telecomunicaciones2  Gracias por comunicarte con la comunidad de cisco, podrías compartir por favor los siguientes comandos una vez que tengas conectados los equipos:
Sh inter estado.
Registro de Sh | en  Ethernet1/16
SH entre  Ethernet1/16 SW
atento a tus respuestas para ayudarte a solventar la falla.
Recuerda apoyar con una ayuda y si esto solventa tu problema por favor tilda en solución de problema.
Hola,
Nexus 7700:
switchport
no shutdown
Catalyst 3560:
end
o
Nexus 7700:
switchport
speed 1000
duplex full
no shutdown
Catalyst 3560:
speed 1000
duplex full
end
saludos
Leomardo
Hola @Leonardo Pena Davila muchas gracias por guiar y asistir a @telecomunicaciones2
Saludos compañeros disculpen por no haber respondido antes, teníamos varios asuntos por resolver.
Finalmente logramos conectar el switch 3560 con el Nexus 7700, los solucionamos cambiando la configuración de la velocidad del puerto en el switch Nexus a 1000Mb.
Les agradezco a todos por su gran aporte.
Saludos
