cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
Dns and routing
athan1234
Level 3
Level 3
I could use some assistance.
I implemented the right part of this scenario, but I'm not sure if it's correct. Vlan 10 is the vlan where the client gets internet  trough meraki they have MEraki MR on the switches , the cleints get internet via wifi vlan 10 ) .
To build an SDWAN between those networks is my goal.
My customer uses FTTH ( left part) , and my goal is to send traffic to the ISR, which is connected via PPOE.
When I disconnects the primary router, they lose internet access. The traffic dosent go out for the ISR
I am observing the ISR router, whose NAt is APIPA ip, and observing that they lack DNS. I am unsure of how I should configure the ISR to acquire DNS.
Note: I configured a DHCP server with vlan 10 and my provider's DNS. I created a test with a user immediately connecting on the SW9200 with vlan 10, and he or she received an internet connection, but the DNS forti
ISR
10 RESPUESTAS 10
Sorry I dont get what you try here,
you have two ISR and you want one to become PPPoE server and other PPPoE Client ??
athan1234
Level 3
Level 3
At least I want the customers to be able to access the ISP router.
The goal is to make the ISR so important that when the primary router, FTTH1, is disconnected, the client no longer receives internet connectivity for the ISR.
When I was creating a trial, I noticed that the clients weren't receiving DNS.
CPE#show ppp interface virtual-access x
PPP Serial Context Info
Interface        : Vi3
PPP Serial Handle: 0xEE000005
PPP Handle       : 0x5B000005
SSS Handle       : 0x7E000006
AAA ID           : 26
Access IE        : 0xA3000005
SHDB Handle      : 0x0
State            : Up
Last State       : Binding
Last Event       : LocalTerm
PPP Session Info
Interface        : Vi3
PPP ID           : 0x5B000005
Phase            : UP
Stage            : Local Termination
Peer Name        : lac
Peer Address     : 1.1.1.10
Control Protocols: LCP[Open] IPCP[Open] CDPCP[Stopped]
Session ID       : 5
AAA Unique ID    : 26
SSS Manager ID   : 0x7E000006
SIP ID           : 0xEE000005
PPP_IN_USE       : 0x11
Vi3 LCP: [Open]
Our Negotiated Options
Vi3 LCP:    MagicNumber 0x023A6422 (0x0506023A6422)
Peer's Negotiated Options
Vi3 LCP:    MRU 1500 (0x010405DC)
Vi3 LCP:    AuthProto CHAP (0x0305C22305)
Vi3 LCP:    MagicNumber 0x52D1CDE4 (0x050652D1CDE4)
Vi3 IPCP: [Open]
Vi3 IPCP:    Address 101.101.101.102 (0x030665656566)
Vi3 IPCP:    PrimaryDNS 4.2.2.2 (0x810604020202)
Our Rejected options
  SecondaryDNS
Vi3 IPCP:    Address 1.1.1.10 (0x03060101010A
 run above command and see if the user get DNS through PPPoE dialer or not
athan1234
Level 3
Level 3
Dialer1 2.139.198.47 YES IPCP up up
Virtual-Access1 unassigned YES unset up up
Virtual-Access2 unassigned YES manual up up
ISR1#show ppp interface Virtual-Access2
Interface : Vi2
PPP Serial Handle: 0xBE000003
PPP Handle : 0xEC000002
SSS Handle : 0xF0000004
AAA ID : 4035
Access IE : 0xF6000002
SHDB Handle : 0x0
State : Up
PPP Session Info
Interface : Vi2
PPP ID : 0xEC000002
Phase : UP
Peer Name : hl4mvn3-101
Peer Address : 192.168.144.1
Session ID : 2
AAA Unique ID : 4035
SSS Manager ID : 0xF0000004
SIP ID : 0xBE000003
PPP_IN_USE : 0x11
Vi2 LCP: [Open]
Vi2 LCP: MRU 1492 (0x010405D4)
Vi2 LCP: MagicNumber 0x3170C613 (0x05063170C613)
Vi2 LCP: MRU 1500 (0x010405DC)
Vi2 LCP: AuthProto CHAP (0x0305C22305)
Vi2 LCP: MagicNumber 0x6512D0D9 (0x05066512D0D9)
Vi2 IPCP: [Open]
Vi2 IPCP: Address 2.139.198.47 (0x0306028BC62F)
Vi2 IPCP: Address 192.168.144.1 (0x0306C0A89001)
ISR1#
ISR1#
ISR1#show ppp interface Virtual-Access1
Interface : Vi1
PPP Serial Handle: 0x0
PPP Handle : 0x0
SSS Handle : 0x0
AAA ID : 0
Access IE : 0x0
SHDB Handle : 0x0
State : Down
Last State : Init
Last Event : None
and it answer your Q, even if you ask dns through dialer you dont get DNS server IP from PPPoE Server.
Yes , I know so How then can I obtain DNS using the provider?
The ISR setup was there, right?
ppp ipcp dns request <<- only check this command is appear in show run
athan1234
Level 3
Level 3
yes iI put before that command it iwas not the solution
Yes the PPPoE Server must push DNS if the PPPoE client request it.
from your side I think you dont have option except
LAN-ISR
you push ISR to LAN client (via DHCP)
and then your router will do lookup and you can specify DNS server 8.8.8.8
this make client ask DNS from router and router will proxy the DNS request to 8.8.8.8.
athan1234
Level 3
Level 3
Hence, each vlan would need to have its own dhcp and DNS setup on the ISR it is crazy ?
I would like to get the DNS via my provider
