Aviso: la función para cargar archivos ha sido deshabilitada, lamentamos los inconvenientes.
cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
Help, configuring RIP
bautiarcangeli
Hello. I don't understand why hosts on the 192.168.10.0/24 subnet can't connect to other hosts on other subnets. I need help please.
Thats hosts cant connect to others hosts
1 SOLUCIÓN ACEPTADA
Soluciones aceptadas
Do the hosts on the 192.168.10.0/24 subnet have default gateways configured that point to their first-hop router? Does that first-hop router (RT10?) have a route to the other subnets in its routing table? Does the last-hop router (the one for the remote hosts) have a route back to the 192.168.10.0/24 subnet? Do the remote hosts have default gateway configurations?
Disclaimers: I am long in CSCO. Bad answers are my own fault as they are not AI generated.
Ver la solución en mensaje original publicado
3 RESPUESTAS 3
bautiarcangeli
I forget to mention that the cisco file of my network is for download. Sorry and thanks in advance
bautiarcangeli
You are right. I  forget that the RT10 need to have a route to the other subnets, my bad. Thank you so much.
