cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
help for aironet 1850i-a-k9 Acces Point
arielbarrozo22
Cuando trato de meter la part.bin por tftp carga y todo pero no pasa de ahi
Booting from tftp
No such device:
No such device:
Full duplex link
Port:2 speed 1000Mbps
Using eth0 device
TFTP from server 192.168.1.254; our IP address is 192.168.1.1
Filename 'part.bin'.
Load address: 0x45000000
Loading: #################################################################
done
Bytes transferred = 58827167 (381a19f hex)
Signature returns 0
Image signing verification success, continue to run...
Using machid 0x1260 from environment
Starting image ...
[01/01/1970 00:00:00.0000] CPU: ARMv7 Processor [512f04d0] revision 0 (ARMv7), cr=10c5387d
[01/01/1970 00:00:00.0000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[01/01/1970 00:00:00.0000] Machine: Cisco Systems 11ac Wave2 Wifi Access Point
[01/01/1970 00:00:00.0000] Memory policy: ECC disabled, Data cache writealloc
[01/01/1970 00:00:00.0000] Kernel command line: ubi.mtd=0 crashkernel=500M-:64M@1280M usbcore.authorized_default=0 console=ttyHSL1,9600n8 activepart=tftp activeboot=0 wdgtriggered=0
[01/01/1970 00:00:00.1500] CPU1: Booted secondary processor
[01/01/1970 00:00:00.2200]
[01/01/1970 00:00:00.2200] +++ hydra_ap_gpio_value =3
[01/01/1970 00:00:36.2088] ACPU PVS: 1
[01/01/1970 00:00:38.0283] buginf tty flushing thread started, ttyport=eec95a90
[01/01/1970 00:00:38.3682] ERROR: unknown nand device manuf=1 devid=8a
[01/01/1970 00:04:36.2938] INFO: task swapper/0:1 blocked for more than 120 seconds.
[01/01/1970 00:04:36.3738] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message[01/01/1970 00:04:36.4737] Backtrace:
[01/01/1970 00:04:36.5137] [<c04092c0>] (__schedule+0x0/0x638) from [<c0409a08>] (schedule+0x6c/0x70)
[01/01/1970 00:04:36.6237] [<c040999c>] (schedule+0x0/0x70) from [<c0407b90>] (schedule_timeout+0x20/0x1e0)
[01/01/1970 00:04:36.7437] [<c0407b70>] (schedule_timeout+0x0/0x1e0) from [<c0409070>] (wait_for_common+0x14c/0x1a0)
[01/01/1970 00:04:36.8636] r8:ef343d48 r7:00010000 r6:ef342000 r5:ef343d4c r4:7fffffff
[01/01/1970 00:04:36.9536] [<c0408f24>] (wait_for_common+0x0/0x1a0) from [<c04090dc>] (wait_for_completion+0x18/0x1c)
[01/01/1970 00:04:37.0836] [<c04090c4>] (wait_for_completion+0x0/0x1c) from [<c0020a04>] (msm_dmov_exec_cmd+0x98/0x14c)
[01/01/1970 00:04:37.2035] [<c002096c>] (msm_dmov_exec_cmd+0x0/0x14c) from [<c02e2900>] (flash_onenand_probe+0x2e0/0x46c)
[01/01/1970 00:04:37.3335] r7:702560a0 r6:c096090c r5:eecf6e64 r4:ffdfc000
[01/01/1970 00:04:37.4135] [<c02e2620>] (flash_onenand_probe+0x0/0x46c) from [<c02e2aa4>] (msm_onenand_scan+0x18/0x130)
[01/01/1970 00:04:37.5434] [<c02e2a8c>] (msm_onenand_scan+0x0/0x130) from [<c03f69e0>] (msm_nand_probe+0x404/0x5c0)
[01/01/1970 00:04:37.6634] r5:eecf6e64 r4:eecf6c00
[01/01/1970 00:04:37.7134] [<c03f65dc>] (msm_nand_probe+0x0/0x5c0) from [<c02a6430>] (platform_drv_probe+0x20/0x24)
[01/01/1970 00:04:37.8433] [<c02a6410>] (platform_drv_probe+0x0/0x24) from [<c02a50bc>] (driver_probe_device+0xdc/0x220)
[01/01/1970 00:04:37.9633] [<c02a4fe0>] (driver_probe_device+0x0/0x220) from [<c02a5270>] (__driver_attach+0x70/0x94)
[01/01/1970 00:04:38.0932] r8:eed3ab80 r7:c08a07c0 r6:c08731cc r5:c088f230 r4:c0873198
[01/01/1970 00:04:38.1832] r3:00000000
[01/01/1970 00:04:38.2232] [<c02a5200>] (__driver_attach+0x0/0x94) from [<c02a369c>] (bus_for_each_dev+0x54/0x94)
[01/01/1970 00:04:38.3432] r6:c02a5200 r5:c088f230 r4:00000000 r3:c02a5200
[01/01/1970 00:04:38.4231] [<c02a3648>] (bus_for_each_dev+0x0/0x94) from [<c02a4bd4>] (driver_attach+0x24/0x28)
[01/01/1970 00:04:38.5431] r6:c088dc28 r5:c088f230 r4:c072004c
[01/01/1970 00:04:38.6131] [<c02a4bb0>] (driver_attach+0x0/0x28) from [<c02a4784>] (bus_add_driver+0xe4/0x248)
[01/01/1970 00:04:38.7230] [<c02a46a0>] (bus_add_driver+0x0/0x248) from [<c02a57c8>] (driver_register+0xa8/0x128)
[01/01/1970 00:04:38.8430] [<c02a5720>] (driver_register+0x0/0x128) from [<c02a6714>] (platform_driver_register+0x4c/0x60)
[01/01/1970 00:04:38.9730] [<c02a66c8>] (platform_driver_register+0x0/0x60) from [<c0720060>] (msm_nand_init+0x14/0x1c)
[01/01/1970 00:04:39.1029] [<c072004c>] (msm_nand_init+0x0/0x1c) from [<c0008760>] (do_one_initcall+0xb4/0x178)
[01/01/1970 00:04:39.2229] [<c00086ac>] (do_one_initcall+0x0/0x178) from [<c0700aac>] (kernel_init+0x124/0x20c)
[01/01/1970 00:04:39.3329] [<c0700988>] (kernel_init+0x0/0x20c) from [<c0063658>] (do_exit+0x0/0x7e4)
1 SOLUCIÓN ACEPTADA
Soluciones aceptadas
balaji.bandi
what is that part.bin contains ?
if you looking to install mobility express follow below video :
https://www.youtube.com/watch?v=XpStmxLBMd0
BB
Ver la solución en mensaje original publicado
Cisco Aironet 1852i-E-K9 upgrade CAPWAP to mobility Express http://www.cisco.com/c/en/us/td/docs/wireless/access_point/mob_exp/82/user_guide/b_ME_User_Guide_82/b_ME_User_Guide_82_chapter_01000.html First part is again recoreded with samsung s7 edge. sorry for the shaking in the video default user:
1 RESPUESTA 1
balaji.bandi
BB
