I´m trying to enable intervlan routing between vlan 902 and vlan 903. I'm not sure that If the switch has the network-essentials license I can achieve this. I tried using "ip routing" command to enable ip routing but every time I try this I get the next exit: "
% Incomplete command.".. I don't know if I have to put something else with this command or the switch doesn't support this feature. I have already created the 902 and 903 vlans, from inside the switch I can ping the hosts in both vlans but when I try to ping one host from vlan 902 to a host in vlan 903 I get not answer.
I have the cisco switch IE3300-8T2S with Cisco IOS XE Software, Version 17.06.03
