cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
15
ÚTIL
Respuestas
Licensing Status Not Applicable C9300
Jonmikhail102
We have a new switch C9300-48UXM, we would like to enable it smart license by reservation method, but we see the next status on the switch : Smart Licensing Status: Registration Not Applicable/Not Applicable
Is this state normal?
How can we change it?
C9300_DNAC#sh ver
Cisco IOS XE Software, Version 17.03.03
Cisco IOS Software [Amsterdam], Catalyst L3 Switch Software (CAT9K_IOSXE), Version 17.3.3, RELEASE SOFTWARE (fc7)
Copyright (c) 1986-2021 by Cisco Systems, Inc.
Compiled Thu 04-Mar-21 12:32 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2021 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
BOOTLDR: System Bootstrap, Version 17.3.2r, RELEASE SOFTWARE (P)
BMV_C9300_DNAC uptime is 1 day, 1 hour, 13 minutes
Uptime for this control processor is 1 day, 1 hour, 15 minutes
System returned to ROM by PowerOn
System image file is "flash:packages.conf"
Last reload reason: PowerOn
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Technology Package License Information:
Technology-package Technology-package
Current Type Next reboot
network-advantage Smart License network-advantage
dna-advantage Subscription Smart License dna-advantage
AIR License Level: AIR DNA Advantage
Next reload AIR license Level: AIR DNA Advantage
cisco C9300-48UXM (X86) processor with 1331521K/6147K bytes of memory.
Processor board ID
2 Virtual Ethernet interfaces
4 Gigabit Ethernet interfaces
36 2.5 Gigabit Ethernet interfaces
20 Ten Gigabit Ethernet interfaces
2 TwentyFive Gigabit Ethernet interfaces
2 Forty Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
8388608K bytes of physical memory.
1638400K bytes of Crash Files at crashinfo:.
11264000K bytes of Flash at flash:.
Base Ethernet MAC Address : b0:8b:d0:d3:1d:80
Motherboard Assembly Number : 73-18277-05
Motherboard Serial Number :
Model Revision Number : A0
Motherboard Revision Number : A0
Model Number : C9300-48UXM
System Serial Number :
CLEI Code Number :
Switch Ports Model SW Version SW Image Mode
* 1 65 C9300-48UXM 17.03.03 CAT9K_IOSXE INSTALL
Configuration register is 0x102
Thanks & Regards!
2 RESPUESTAS 2
Julio E. Moisa
The easy way to fix that is request assistance to your Cisco Partner, basically they must associate the license to your smart account then you must create a token under your smart account profile then apply this to the switch, once it is applied you can restart the switch, take in consideration you must provide internet access to the management IP of the switch.
Regards.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Thank you for communicating with the Cisco community, if you want to do it in a reserved way you will not need an internet connection
There is this option, you must do it with Cisco Licensing support personnel, this is done in three steps, you make a reservation, download a hash of the equipment and apply it to the account
Remember to qualify this answer
