el 08-08-2018 12:11 PM
Buenas tardes, espero se encuentren muy bien.
Acabo de activar el terminal monitor en mi Sw de una localidad remota. Ahora me aparecen en el SW los siguientes mensajes:
EdAdmZul-01#
*Mar 1 01:37:47.715: %IP-3-LOOPPAK: Looping packet detected and dropped -
src=172.20.16.15, dst=172.20.16.1, hl=20, tl=78, prot=17, sport=137, dport=137
in=Vlan118, nexthop=172.20.16.1, out=Vlan118
options=none
-Process= "IP Input", ipl= 0, pid= 137
-Traceback= 96AC40 A8FDCC A90070 A91AC0 A9271C A9058C A908AC C2269C C2281C BFFDA
8 AAB5EC A6DBD8 A827F8 A80D7C A80EA0 A81104
EdAdmZul-01#
*Mar 1 01:38:48.339: %IP-3-LOOPPAK: Looping packet detected and dropped -
options=none
EdAdmZul-01#
*Mar 1 01:39:48.662: %IP-3-LOOPPAK: Looping packet detected and dropped -
src=172.20.17.98, dst=172.20.17.97, hl=20, tl=96, prot=17, sport=137, dport=137
in=Vlan122, nexthop=172.20.17.97, out=Vlan122
options=none
EdAdmZul-01#
*Mar 1 01:40:48.682: %IP-3-LOOPPAK: Looping packet detected and dropped -
options=none
EdAdmZul-01#
*Mar 1 01:41:54.130: %IP-3-LOOPPAK: Looping packet detected and dropped -
src=172.20.16.56, dst=172.20.16.1, hl=20, tl=78, prot=17, sport=137, dport=137
options=none
EdAdmZul-01#
*Mar 1 01:42:54.805: %IP-3-LOOPPAK: Looping packet detected and dropped -
options=none
EdAdmZul-01#
*Mar 1 01:44:02.082: %IP-3-LOOPPAK: Looping packet detected and dropped -
src=172.20.16.36, dst=172.20.16.1, hl=20, tl=78, prot=17, sport=137, dport=137
options=none
EdAdmZul-01#
*Mar 1 01:45:02.656: %IP-3-LOOPPAK: Looping packet detected and dropped -
src=172.20.17.35, dst=172.20.17.33, hl=20, tl=78, prot=17, sport=137, dport=137
in=Vlan120, nexthop=172.20.17.33, out=Vlan120
options=none
EdAdmZul-01#
*Mar 1 01:46:08.531: %IP-3-LOOPPAK: Looping packet detected and dropped -
options=none
EdAdmZul-01#
Podrian indicarme que clase de alerta es esta? Primera ves que observo esto. Y cual seria la solución si es un problema, de cual nivel de gravedad seria?
Muy atento a sus comentarios!
Saludos,
Jose Corniel.
08-08-2018 02:12 PM - editado 08-08-2018 03:36 PM
Hola Jose,
Veo que estan aplicadas a las SVI, es este tu equipo de distribucion/core y tu DHCP esta en un servidor? El IP helper-address se configura cuando tienes un servidor DHCP externo ya sea un router remoto o un servidor que tenga ese rol. Esta el DHCP configurado en ese mismo equipo o en un servidor (digamos Window server o Linux?)
Si tu DHCP esta en un servidor y a través de esas SVI estas haciendo los DHCP Request, mejor verifica antes de remover todo, y que en el helper-address estes agregando la direccion IP correcta del servidor de DHCP, de lo contrario tus computadoras podrian dejar de obtener direccion IP.
Ejemplo:
Servidor Windows Server 2012 (DHCP) tiene IP 172.18.130.15
Entonces:
interface Vlan118
description Vlan Edificio Administrativo Maracaibo
ip address 172.20.16.1 255.255.255.0
no ip helper-address 172.20.16.105
ip helper-address 172.18.130.15
Si te das cuenta las direcciones IP en rojo pertenecen a el mismo segmento de red. Cuando el servidor esta en en el mismo segmento de red no necesitas configurar el ip helper-address
Saludos
el 08-09-2018 05:26 AM
08-09-2018 05:32 AM - editado 08-09-2018 05:41 AM
Que tal José,
Por lo general y desde mi punto de vista recomendable, es mejor utilizar un servidor dedicado para DHCP, tu puedes tener múltiples servidores de DHCP y configurar muchos ip helper-address bajo tus SVI, y creo que los administradores de servidores también pueden indicar cual servidor DHCP sera primario y secundario o mantener deshabilitado el secundario.
Si los DHCP scopes de cada uno de tus redes LAN estan creadas en el DHCP server, seria mejor que en el ip helper-address se configure la direccion IP del servidor. OJO las redes LAN deben poder comunicarse con ese servidor.
el 08-09-2018 06:27 AM
Hola Jose,
Suponiendo que el servidor DHCP está en la IP 172.20.16.105, te paso a mostrar lo que podrías editar:
interface Vlan118
ip helper-address 172.20.16.105 -> Eliminar ya que el servidor está en la misma red.
ip helper-address 172.20.16.1-> Eliminar
interface Vlan119
description Vlan Laboratorio
ip address 172.20.17.1 255.255.255.224
ip helper-address 172.20.17.1-> Eliminar
interface Vlan120
description Vlan Romana-Transporte
ip address 172.20.17.33 255.255.255.224
ip helper-address 172.20.17.33 -> Eliminar
interface Vlan121
description Vlan Produccirn - Planta
ip address 172.20.17.65 255.255.255.224
ip helper-address 172.20.17.65 -> Eliminar
interface Vlan122
description Vlan Almacen de Repuestos
ip address 172.20.17.97 255.255.255.224
ip helper-address 172.20.17.97 -> Eliminar
Podrías eliminar también las exclusiones.
Saludos
Descubra y salve sus notas favoritas. Vuelva a encontrar las respuestas de los expertos, guías paso a paso, temas recientes y mucho más.
¿Es nuevo por aquí? Empiece con estos tips. Cómo usar la comunidad Guía para nuevos miembros
Navegue y encuentre contenido personalizado de la comunidad
