cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
need help with routing
ino
i have a SoHo isr c1111 with 4 switch ports
a device is connected to it which i can ping from the c1111 where its connected to and from the c2960
but from no where else neither from a vpn connection to the c1111 or from devices connected to the c2960
interface GigabitEthernet0/1/3
 switchport access vlan 88
 switchport mode access
c2960x
interface GigabitEthernet1/0/1
 description Trunk 0/1/1
 switchport trunk allowed vlan 88.99
 switchport mode trunk
 switchport port-security maximum 100
 switchport port-security violation restrict
interface GigabitEthernet1/0/2
 description V7 Route
 switchport access vlan 7
 switchport port-security maximum 9
this are connecter to (on the isr c1111)
interface GigabitEthernet0/1/1
 Description Trunk
interface GigabitEthernet0/1/2
 switchport port-security maximum 25
 routing table of c1111
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
S*    0.0.0.0/0 is directly connected, Cellular0/2/0
      10.0.0.0/8 is variably subnetted, 11 subnets, 2 masks
C        10.0.0.0/24 is directly connected, Vlan7
L        10.0.0.1/32 is directly connected, Vlan7
D        10.0.10.0/24 [90/3072] via 10.99.99.2, 09:49:48, Vlan99
D        10.0.20.0/24 [90/3072] via 10.99.99.2, 09:49:48, Vlan99
D        10.0.30.0/24 [90/3072] via 10.99.99.2, 09:49:48, Vlan99
S        10.0.100.2/32 is directly connected, Virtual-Access1
S        10.0.100.5/32 is directly connected, Virtual-Access2
C        10.1.1.1/32 is directly connected, Loopback0
C        10.99.99.0/24 is directly connected, Vlan99
L        10.99.99.1/32 is directly connected, Vlan99
C        10.100.100.1/32 is directly connected, Loopback1
      x.0.0.0/32 is subnetted, 1 subnets
C        x.x.23.141 is directly connected, Cellular0/2/0
D     192.168.0.0/24 [90/3072] via 10.99.99.2, 09:49:48, Vlan99
D     192.168.1.0/24 [90/3072] via 10.99.99.2, 09:49:48, Vlan99
D     192.168.10.0/24 [90/3072] via 10.99.99.2, 09:49:48, Vlan99
      192.168.88.0/24 is variably subnetted, 3 subnets, 2 masks
C        192.168.88.0/24 is directly connected, Vlan88
L        192.168.88.100/32 is directly connected, Vlan88
S        192.168.88.200/32 is directly connected, Vlan99
routing table of 2960
Gateway of last resort is 10.0.0.1 to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via 10.0.0.1
S        10.0.0.1/32 is directly connected, Vlan7
L        10.0.0.2/32 is directly connected, Vlan7
C        10.0.10.0/24 is directly connected, Vlan101
L        10.0.10.1/32 is directly connected, Vlan101
C        10.0.20.0/24 is directly connected, Vlan102
L        10.0.20.1/32 is directly connected, Vlan102
C        10.0.30.0/24 is directly connected, Vlan103
L        10.0.30.1/32 is directly connected, Vlan103
L        10.99.99.2/32 is directly connected, Vlan99
      192.168.0.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.0.0/24 is directly connected, Vlan1920
L        192.168.0.1/32 is directly connected, Vlan1920
      192.168.1.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.1.0/24 is directly connected, Vlan1921
L        192.168.1.1/32 is directly connected, Vlan1921
      192.168.10.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.10.0/24 is directly connected, Vlan1930
L 192.168.10.1/32 is directly connected, Vlan1930
      192.168.88.0/24 is variably subnetted, 2 subnets, 2 masks
L 192.168.88.200/32 is directly connected, Vlan88
on the c1111 i have
router eigrp 10
 network 10.99.99.0 0.0.0.255
on the c2960
router eigrp 10
 network 10.0.0.0
 network 192.168.0.0 0.0.255.255
 eigrp stub connected summary
 what do i need to do to be able to reach 192.168.88.1 (the device in question) from another device connected to the c2960 or from a vpn connection to the c1111
as mentioned i can ping it from both c1111 and c2960 just not from other devices connected to the switch
1 RESPUESTA 1
ino
sorry not a picaso
i can ping anything from any where
except 192.168.88.1 i can from c1111 an c2960 but from no where else
