Aviso: la función para cargar archivos ha sido deshabilitada, lamentamos los inconvenientes.
cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
17
Respuestas
PROBLEM WITH LOCAL HTTP SERVER
manstrik059
My local server does not work (I cannot go to the web page of this server from the 33.33.33.0 network), although I can from the 192 168.1.0 network, but there I use a gre tunnel, maybe problem in nat, in the middle I use ospf and announce other networks in ospf. Please help me
1 SOLUCIÓN ACEPTADA
Soluciones aceptadas
17 RESPUESTAS 17
@manstrik059
 You have the same problem as @andrew005 . Check his post "https://community.cisco.com/t5/discusiones-routing-y-switching/problem-with-lan-http-server/m-p/5223914#M11217
I just fixed his problem, you can take the solution from there.
manstrik059
i check his post but ur solving don't help
Ok, let me see you file
manstrik059
thank you i am waiting
manstrik059
haven't you forgotten about me?
No...your problem was related to NAT. I fixed it by adding one line on the ACL. Check this out
manstrik059
can you tell me what you changed?
I added the following line on R9
ip access-list extended PUBLIC-ACCESS
permit ip 33.33.33.0 0.0.0.255 host 192.168.0.10
deny ip 33.33.33.0 0.0.0.255 192.168.0.0 0.0.0.255
deny ip 192.168.0.0 0.0.0.255 33.33.33.0 0.0.0.255
permit ip any any
End this on Router 7
router ospf 1
router-id 7.7.7.7
log-adjacency-changes
redistribute static subnets
redistribute connected subnets
passive-interface GigabitEthernet1/0
network 17.12.18.72 0.0.0.3 area 0
manstrik059
but your photo is not my project and it still doesn't work for me
Oh sorry LOL..mixed up the projects. Just a second
Because you have a Static NAT, you need to call the Router IP address, not the server IP address
ip nat inside source list FOR-NAT interface GigabitEthernet0/0 overload
ip nat inside source list PUBLIC-ACCESS interface GigabitEthernet0/0 overload
ip nat inside source static tcp 192.168.0.10 80 10.10.10.5 80
ip classless
If you call the server on port 443, you can call the server directly. Because there will be no NAT on port 443
send me project pls
of course
Maybe you want to help me with a new problem in my profile?)
