cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
16
Respuestas
Problema con DHCP Snooping
uliflocol
Hola a todos.
Tengo un problema con dhcp snooping en packet tracer, cuando doy el comando show ip dhcp snooping me arroja el siguiente "DHCP snooping is operational on following VLANs: none"
Lo tengo configurado de la siguiente forma:
ip dhcp snooping vlan X,X,X,X
no ip dhcp snooping information option
ip dhcp snooping
En interfaces troncales tengo el trust activo y en interfaces de acceso el limit rate, sin embargo, me aparece el mensaje que comenté al inicio y el DHCP no me asigna direcciones a menos que apague el dhcp snooping globalmente. ¿Qué podría estar pasando?
De antemano gracias
1 SOLUCIÓN ACEPTADA
Soluciones aceptadas
  About the NAT you need to configure on the interface vlan. It does not accept on the  physical interface. This is not like a router.
 conf t
 interface vlan 100
 ip nat (inside/outside)
About the DHCP snooping .  there is nothing wrong with your config. At least on the file I am attaching.
But, here is the problem.  The port-channel should be a trust port. It turns out that in PacketTracer you can not do that. In real device you can. So, if you configure the physical interface like you did, this does not reflect on the Port-channel. Actually it should be the opposite, configuration on the port-channel will repflect on the physical interface.
 You can prove that by changin the Yoali (Ingeniería) to vlan 20 and Miguel (Gerencia) to vlan 30. Because this way, they will not cross the DHCP request through the Port-channel. The DHCP request wil be sent to the router on the same switch and the router will sent as unicast to DHCP server.
Ver la solución en mensaje original publicado
16 RESPUESTAS 16
 Did you create the VLAN on the switch ?
Attach the PacketTracer file here. Zip it first.
Yes, "show vlan brief" display active vlans
I had success running the command. It might be some problem in your end. Try to close the project and open again.
I did not change any configuration .
SW1#sh ip dhcp snooping
Switch DHCP snooping is enabled
DHCP snooping is configured on following VLANs:
10,20,30,100
none
Smartlog is configured on following VLANs:
none
Smartlog is operational on following VLANs:
none
DHCP snooping is configured on the following L3 Interfaces:
Insertion of option 82 is disabled
circuit-id default format: vlan-mod-port
remote-id: 000C.CF1A.D759 (MAC)
Option 82 on untrusted port is not allowed
Verification of hwaddr field is enabled
Verification of giaddr field is enabled
DHCP snooping trust/rate is configured on the following Interfaces:
Interface Trusted Allow option Rate limit (pps)
GigabitEthernet1/0/3 yes yes unlimited
Custom circuit-ids:
GigabitEthernet1/0/5 no no 5
Custom circuit-ids:
GigabitEthernet1/0/1 yes yes unlimited
Custom circuit-ids:
GigabitEthernet1/0/2 yes yes unlimited
Custom circuit-ids:
SW1#
Is that message normal? When I try to obtain IP by DHCP on any PC it does not allow me
 It is not normal but as I said there might be some problem on your file. When I run the command I got the right output.
 Try to close the project and open again. Or add a new switch and configure it again
I have tried to configure the SW again, close the file multiple times and that message continues to appear, in addition to the fact that DHCP does not give addresses
On this file, the DHCP is working. But you put too many config at once. Let´s try to go slowly just to see what is wrong.
 Try to add the DHCP snoop config and test.
DHCP doesn't work for me. I downloaded the file and ran it, I tried the DHCP and it doesn't give me addresses. It only gives it to me if I turn off snooping with the no ip dhcp snooping command
 I will take a look and get back to you.
Thank you so much. Another question, why doesn't it allow me to enable the "ip nat outside" command on the interface that faces the internet? nothing related to nat appears when I enter the interface.
 conf t
 interface vlan 100
About PAT, how can I traduce 150.1.1.2 (int g1/0/24) to Vlan 100 IP?
I tried to configure
interface vlan 100
ip nat inside
But it's not clear to me how to get to the interface 150.1.1.1 (Internet) because I can't configure nat on the interface with No switchport.
About Snooping, Thank you so much, It was pretty clear to me, thanks for your time.
I recommend you to use a router instead.  As the "Internet"  is actually a router, it would be easier for you put a router on your side and to the config on the router.
 In order to to it on th switch you need that the port between switch and Internet must be in Layer2 and then you add it to the Vlan 100 and do the NAT on the vlan 100.  But, if you put the interface in layer2 on the switch  you end up having problem on the Internet site.
I understand, thanks for everything
