cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
7
Respuestas
Problemas de pings
nestorarce630
Buenos dias, estoy teniendo problemas con los pings, todos los componentes deben dar pings entre sí, pero tengo problemas en ello sobretodo en dar pings entre red 2 y red 3
Adjunto los archivos correspondientes.
Gracias de antemano.
1 SOLUCIÓN ACEPTADA
Soluciones aceptadas
@nestorarce630
 Your ip address are totally  wrong. R2 and RS have the same IP address. Other routers are not on the same networks.
R1 - R2
You are connecting R1 to  192.168.1.249 in R2
Ver la solución en mensaje original publicado
7 RESPUESTAS 7
@nestorarce630
R1 - R2
What do I need to do to fix this in Packet tracer?
Take you doc file, open up your PackeTracer project and carefully assign the IP address just like it was told on the doc.
To make it easier for you, connect R1 Serial 0/0/0 to R2 Serial 0/0/0.  Then, assign IP address accordingly.
192.168.1.241 is the serial 0/0/0 in R1 and 192.168.1.242 is the serial 0/0/0 in Router 2. Both must be connected.
Keep doing this for all routers and interface.
Sorry, but I don't have much time. I would like to correct the .pkt file
If you do this carefully, your network will work and it will take much less time than trying to fix this. You basically switch all the IP address between routers and interface.
I'm worried, as there isn't much time but I appreciate the help, the problem I have is sending ping between red 2 and red 3
It is not @nestorarce630 .
 I fixed but you need to pay attention when doing this
