el 12-31-2023 03:11 PM
On above topology, I'm trying to create or simulate a loop with the route 192.168.200.1. I'm expecting to have that route back and forth between R3 and R4 but it is not happenning. Attached table route from R3 and R4 so I can apply the tag filtering to avoid it.
R3
R4
Even though it R4 has this route in the ospf database it is not installing it.
Please heeelp
¡Resuelto! Ir a solución.
12-31-2023 03:22 PM - editado 01-01-2024 02:31 AM
Happy new Year
here the lab show the suboptimal and ROUTING LOOP
R1-R2 EIGRP 100
R1-R3 EIGRP 100
R2-R4 OSPF 100
R3-R4 OSPF 100
there is redistribute between EIGRP and OSPF (two way redistribute)
Now we redistribute LO 1.1.1.1 in R1
the prefix must appear in R2 & R3 as D EX but only R3 show that
R2 learn the prefix via O E2 not via D EX.
this because the O E2 have AD 110 and D EX have AD 170
check this note
and you are free to Ask anything
MHM
Happy new Year
R1-R2 EIGRP 100
R1-R3 EIGRP 100
R2-R4 OSPF 100
R3-R4 OSPF 100
check this note
MHM
el 01-01-2024 07:23 PM
The firts question would be, Why R3 is learning it from the right source and R2 does not??
el 01-01-2024 08:02 PM
it randomly, you can see R2 or R3 have routing loop (suboptimal) path
I close lab open again and you can see now the R3 learn correct path and R2 not
MHM
Descubra y salve sus notas favoritas. Vuelva a encontrar las respuestas de los expertos, guías paso a paso, temas recientes y mucho más.
¿Es nuevo por aquí? Empiece con estos tips. Cómo usar la comunidad Guía para nuevos miembros
Navegue y encuentre contenido personalizado de la comunidad
