cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
Router Redistribution Question
davidcriollo
On above topology, I'm trying to create or simulate a loop with the route 192.168.200.1. I'm expecting to have that route back and forth between R3 and R4 but it is not happenning. Attached table route from R3 and R4 so I can apply the tag filtering to avoid it.
R3
R4
Even though it R4 has this route in the ospf database it is not installing it.
Please heeelp
1 SOLUCIÓN ACEPTADA
Soluciones aceptadas
Happy new Year
here the lab show the suboptimal and ROUTING LOOP
R1-R2 EIGRP 100
R1-R3 EIGRP 100
R2-R4 OSPF 100
R3-R4 OSPF 100
there is redistribute between EIGRP and OSPF (two way redistribute)
Now we redistribute LO 1.1.1.1 in R1
the prefix must appear in R2 & R3 as D EX but only R3 show that
R2 learn the prefix via O E2 not via D EX.
this because the O E2 have AD 110 and D EX have AD 170
check this note
and you are free to Ask anything
MHM
Ver la solución en mensaje original publicado
3 RESPUESTAS 3
Happy new Year
R1-R2 EIGRP 100
R1-R3 EIGRP 100
R2-R4 OSPF 100
R3-R4 OSPF 100
check this note
MHM
The firts question would be, Why R3 is learning it from the right source and R2 does not??
it randomly, you can see R2 or R3 have routing loop (suboptimal) path
I close lab open again and you can see now the R3 learn correct path and R2 not
MHM
