cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
RV340 and secondary Gateway
John Martin
Hi ,
I am interested to find a solution about my RV340 to setup something like a secondary gateway or backup gateway when the forst gateway fail.
I don't know if RV340 has the posibility to check the connection tyo internetr, for example, a ping to 8.8.8.8 and when this ping fail, change automaticaly to the secondary gateway.
Any advice ?
Kind regards
1 RESPUESTA 1
Julio E. Moisa
What are you looking is a failover solution, please see the following link, it should answer your question:
https://www.cisco.com/c/en/us/support/docs/smb/routers/cisco-rv-series-small-business-routers/KMGMT-1568_WAN_Load_balancing_on_RV340_Router.html
Regards.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
