el 10-28-2023 11:03 PM
I got a simple project using 4 different networs, I'm trying to comunicate their users using dinamic routing with RIP protocol.
I got this simulation.
I configure the routers:
R0
R1
R0 - RIP
R1-RIP
The protocol route the serial interface, but it doesn't work with the terminal users, i hope that someone could give me an advaice.
I'm using the last version
Thank you
el 10-28-2023 11:26 PM
@DavidArias05 hi,
as per your captures, you added 20.20.20.0 range to R1 and 172.16.0.0 range in R0. according to diagram those are connected other way. can you try swapping those networks between router r1 and r0. in RIP you need to advertise connected networks.
el 10-29-2023 05:32 AM
10-29-2023 08:35 AM - editado 10-29-2023 08:35 AM
Hello @DavidArias05,
Add redistribute connected under each router rip process.
el 10-29-2023 02:05 PM
I already fix the issue, i add their own network on the RIP configuration, and now i can comunicate the terminal user
thaks four your help
Descubra y salve sus notas favoritas. Vuelva a encontrar las respuestas de los expertos, guías paso a paso, temas recientes y mucho más.
¿Es nuevo por aquí? Empiece con estos tips. Cómo usar la comunidad Guía para nuevos miembros
Navegue y encuentre contenido personalizado de la comunidad
