cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
simple RIP Config
DavidArias05
I got a simple project using 4 different networs, I'm trying to comunicate their users using dinamic routing with RIP protocol.
I got this simulation.
I configure the routers:
R0
R1
R0 - RIP
R1-RIP
The protocol route the serial interface, but it doesn't work with the terminal users, i hope that someone could give me an advaice.
I'm using the last version
Thank you
4 RESPUESTAS 4
@DavidArias05 hi,
as per your captures, you added 20.20.20.0 range to R1 and 172.16.0.0 range in R0. according to diagram those are connected other way. can you try swapping those networks between router r1 and r0. in RIP you need to advertise connected networks.
Good luck
KB
##- thank you, I did the swap of network, but it doesn't work still -##
M02@rt37
Hello @DavidArias05,
Add redistribute connected under each router rip process.
Best regards
DavidArias05
I already  fix the issue, i add their own network on the RIP configuration, and now i can comunicate the terminal user
thaks four your help
