cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
Static routing problem with Packet Tracer
Alii
Hello !
can you please help me with this packet tracer lab! i cannot ping between pc's !
thanks a lot (L)
1 SOLUCIÓN ACEPTADA
Soluciones aceptadas
luis_cordova
Your problem is the IP Gateway configured on the PCs.
You must make sure that the IP Gateway of the PCs is the same as the one you configured in the router interface.
Correct this detail on all the PCs and the ping will be successful.
Ver la solución en mensaje original publicado
2 RESPUESTAS 2
luis_cordova
carlbert1999
You are not setting the default gateway correctly.
