cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
Tráfico entre los VSS
Buenos días,
Es normal que entre dos SW conectados entre sí con la tecnología VSS es normal tanto tráfico , esto debido a que uno equipo esta como principal y el otro como BK.
les comparto el show ver
MDENIQSWCORE#show ver
Cisco IOS Software, s2t54 Software (s2t54-ADVENTERPRISEK9-M), Version 15.5(1)SY1 , RELEASE SOFTWARE (fc6)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Sun 04-Mar-18 06:00 by prod_rel_team
ROM: System Bootstrap, Version 12.2(50r)SYS3, RELEASE SOFTWARE (fc1)
MDENIQSWCORE uptime is 1 year, 6 weeks, 3 days, 9 hours, 31 minutes
Uptime for this control processor is 1 year, 6 weeks, 3 days, 9 hours, 26 minute s
System returned to ROM by Stateful Switchover at 01:18:25 GMT Mon May 7 2018
System restarted at 01:22:33 GMT Mon May 7 2018
System image file is "bootdisk:s2t54-adventerprisek9-mz.SPA.155-1.SY1.bin"
Last reload reason: Standby Handler Reload Shelf
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco C6807-XL (M8572) processor (revision ) with 1785856K/262144K bytes of memory.
Processor board ID SMC1824002C
CPU: MPC8572_E, Version: 2.2, (0x80E80022)
CORE: E500, Version: 3.0, (0x80210030)
CPU:1500MHz, CCB:600MHz, DDR:600MHz
L1: D-cache 32 kB enabled
I-cache 32 kB enabled
Last reset from s/w reset
10 Virtual Ethernet interfaces
150 Gigabit Ethernet interfaces
68 Ten Gigabit Ethernet interfaces
2543K bytes of non-volatile configuration memory.
MDENIQSWCORE#show switch virtual
Switch mode : Virtual Switch
Virtual switch domain number : 100
Local switch number : 2
Local switch operational role: Virtual Switch Active
Peer switch number : 1
Peer switch operational role : Virtual Switch Standby
MDENIQSWCORE#
MDENIQSWCORE#show interfaces tenGigabitEthernet 1/3/4
TenGigabitEthernet1/3/4 is up, line protocol is up (connected)
Hardware is C6k 10000Mb 802.3, address is 0008.e3ff.fd90 (bia 0008.e3ff.fd90)
Description: VSS-LINK (10G 2/3/4)
MTU 9216 bytes, BW 10000000 Kbit/sec, DLY 10 usec,
reliability 255/255, txload 20/255, rxload 11/255
Keepalive set (10 sec)
Full-duplex, 10Gb/s, media type is 10Gbase-SR
input flow-control is on, output flow-control is off
Clock mode is auto
Last input never, output never, output hang never
Last clearing of "show interface" counters 39w2d
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 443418000 bits/sec, 78189 packets/sec
5 minute output rate 784317000 bits/sec, 146833 packets/sec
L2 Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes
L3 in Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes
L3 out Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes
301101410973 packets input, 210897762597850 bytes, 0 no buffer
Received 13871608948 broadcasts (3703292342 multicasts)
0 runts, 2026457765 giants, 0 throttles
0 watchdog, 0 multicast, 0 pause input
601954829781 packets output, 359922186828071 bytes, 0 underruns
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
MDENIQSWCORE#show interfaces tenGigabitEthernet 2/3/4
TenGigabitEthernet2/3/4 is up, line protocol is up (connected)
Description: VSS-LINK (10G 1/3/4)
reliability 255/255, txload 11/255, rxload 22/255
Clock mode is auto
5 minute input rate 867404000 bits/sec, 154580 packets/sec
5 minute output rate 467490000 bits/sec, 80529 packets/sec
601968887580 packets input, 359934344081386 bytes, 0 no buffer
Received 10816286003 broadcasts (329658696 multicasts)
0 runts, 3529527687 giants, 0 throttles
301108922597 packets output, 210903491132544 bytes, 0 underruns
2 RESPUESTAS 2
Julio E. Moisa
Hola,
Borra lo counters de las interfaces y verifica si se siguen incrementando:
clear counter <interface>
Que esta conectado en ambas interfaces? es el enlace entre ellos, podria ser que un dispositivo como switch de acceso tenga conexion unicamente al switch de backup y el trafico que ves sea de transito.
Saludos
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Buenas tardes,
Ambas interfaces conectan  el SW core para armar  el VSS
saludos
JC
