el 11-30-2023 08:36 AM
Hello community:
I have a case, where the UDLD is not working, I have 2 switches at both remote ends and connected by 2-wire fiber.
Both switches have the QSFP-40G-ER4 transceiver and the following was configured on both ports on each end:
errdisable recovery interval 60
int HundredGigE2/0/25
switchport mode trunk
udld port aggressive
channel-group 40 mode active
The C9500-48Y4C switches have firmware 17.06.04
When I disconnect a thread the port goes down but it does not go into the err-disable state that should appear in the switch logs, but does not appear.
Why does it not appear to be that state? Could it be because of the C9500-48Y4C version? Could it be because it is associated with a portchannel? Would it be because of the transceiver? Or would some configuration be missing in said model and version of the equipment?
Please kindly support me with this case.
11-30-2023 08:42 AM - editado 11-30-2023 08:50 AM
What udld mode you run?
Aggresive mode errdisable port.
MHM
el 11-30-2023 10:14 AM
Is aggresive mode
el 11-30-2023 10:22 AM
Both side use aggresive mode.
Ok' but there is also one factor here'
Port channel' portchannel with udld I think this behavior is normal'
One port member will down but the all port channel not go to errdisable.
Check this point.
MHM
el 11-30-2023 10:40 AM
If aggressive mode is on both sides, the settings on both sides are the same.
You do not want the port-chanel to be disabled, only the port HundredGigE2/0/25 on both ends are the same port and rtransceivers, but the err-disable mode does not appear when we disconnect only one fiber strand.
el 11-30-2023 10:43 AM
el 11-30-2023 08:45 AM
both the side cat 9500 ? or what is other side ?
check the UDLD behavior and work in best way :
el 11-30-2023 10:16 AM
el 11-30-2023 10:35 AM
both the sides Cat 9500 ?
before Fibre remove testing, is the UDLD neighbours you see ?
before and after remove fibre can you post below output :
show int HundredGigE2/0/25
show int HundredGigE2/0/25 trans
el 12-01-2023 09:14 AM
appears on both sides.
The neighbors cannot be seen in UDLD, since when removing a thread the port on both sides is down, but since the ports on both sides are configured by UDLD and with the same configuration, the err-disable message should appear but it does not appear in the switch logs.
As an observation, the fiber has 2 wires, and only one wire is removed to validate the operation of the UDLD.
When the 2 threads that the fiber has are present, the port is in the up state, and when we remove the thread the port is in the down state. but the err-disable message does not appear, which should be the normal behavior of the UDLD.
Descubra y salve sus notas favoritas. Vuelva a encontrar las respuestas de los expertos, guías paso a paso, temas recientes y mucho más.
¿Es nuevo por aquí? Empiece con estos tips. Cómo usar la comunidad Guía para nuevos miembros
Navegue y encuentre contenido personalizado de la comunidad
