el 05-24-2025 03:41 PM
We have a lot of IPSEC VPNs L2L using the VTI (interface tunnel , with tunnel mode ipsec ipv4,etc), but always between Cisco routers.
Now I have to establish a VPN L2L with another FW vendor (that probably is not going to have a tunnel interface with ip address,etc).
So the question is should I configure on my side (cisco router) a VTI or "classic" IPSEC tunnel with crypto map and crypto ACLs ? I know the later is going to work but is legacy, but I am not sure if the VTI is going to work with a 3rd party device.
what do you recommend for these cases?
Thank you.
05-28-2025 10:32 AM - editado 05-28-2025 12:02 PM
Does anyone know this? In summary I am asking if VTI is ok to establish a VPN to a 3rd party device and if not what you would configure to establish a VPN from Cisco Router to a 3rd party device.
Thank you.
Regards.
el 06-10-2025 03:29 PM
anyone?
thanks.
Descubra y salve sus notas favoritas. Vuelva a encontrar las respuestas de los expertos, guías paso a paso, temas recientes y mucho más.
¿Es nuevo por aquí? Empiece con estos tips. Cómo usar la comunidad Guía para nuevos miembros
Navegue y encuentre contenido personalizado de la comunidad
