cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
VPN loop problem
andrew005
I have the following task to configure site-to-site VPN with encryption algorithm aes, hashing algorithm sha Diffie-Gellman number
group 2
entered the following commands:
Router0
Router>
Router>en
Router#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Router(config)#crypto isakmp enable
Router(config)#crypto isakmp policy 100
Router(config-isakmp)#encr aes
Router(config-isakmp)#hash sha
Router(config-isakmp)#authentication pre-share
Router(config-isakmp)#group 2
Router(config-isakmp)#ex
Router(config)#crypto isakmp key cisco123 address 22.22.22.2
Router(config)#crypto ipsec transform-set R0 esp-aes esp-sha-hmac
Router(config)#crypto map R0MAP 100 ipsec-isakmp
% NOTE: This new crypto map will remain disabled until a peer
and a valid access list have been configured.
Router(config-crypto-map)#set peer 22.22.22.2
Router(config-crypto-map)#set transform-set R0
Router(config-crypto-map)#match address 151
Router(config-crypto-map)#ex
Router(config)#int fa0/0
Router(config-if)#ip access-group 101 in
Router(config-if)#crypto map R0MAP
*Jan 3 07:16:26.785: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is ON
Router(config-if)#ex
Router(config)#access-list 101 permit ahp host 22.22.22.1 host 22.22.22.2
Router(config)#access-list 101 permit esp host 22.22.22.1 host 22.22.22.2
Router(config)#access-list 101 permit udp host 22.22.22.1 host 22.22.22.2 eq isakmp
Router(config)#access-list 101 permit icmp host 22.22.22.1 host 22.22.22.2 echo
Router(config)#access-list 151 permit ip 192.168.8.0 0.0.0.255 172.32.32.0 0.0.0.255
Router(config)#access-list 151 deny ip any any
Router(config)#ex
Router#
Router>en
Router#conf t
Router(config-isakmp)#crypto isakmp key cisco123 address 22.22.22.1
Router(config)#crypto ipsec transform-set R1 esp-aes esp-sha-hmac
Router(config)#crypto map R1MAP 100 ipsec-isakmp
Router(config-crypto-map)#set peer 22.22.22.1
Router(config-crypto-map)#set transform-set R1
Router(config-if)#crypto map R1MAP
Router(config)#access-list 101 permit ahp host 22.22.22.2 host 22.22.22.1
Router(config)#access-list 101 permit esp host 22.22.22.2 host 22.22.22.1
Router(config)#access-list 101 permit udp host 22.22.22.2 host 22.22.22.1 eq isakmp
Router(config)#access-list 101 permit icmp host 22.22.22.2 host 22.22.22.1 echo
Router(config)#access-list 151 permit ip 172.32.32.0 0.0.0.255 192.168.8.0 0.0.0.255
Router(config)#ex
For some reason, packets are looping between routers. I am adding a diagram. Help solve the problem. I would be grateful for the commands to enter and the updated diagram.
1 SOLUCIÓN ACEPTADA
Soluciones aceptadas
andrew005
1 RESPUESTA 1
andrew005
Already solved
