cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
WS-C3750X-24T-E 15.2(1)E firmware upgrade
dmata
We want and have to upgrade the Cores switch firmware to the Cisco recommended version.
Issue:
Our primary Core SW was blackholing the traffic due to an internal control plane issue or a bug issue,  it happened twice and we had to reboot (cold reboot) the Core SWs (Primary and Backup).
There are no codes or logs that show an error.
Could you please recommend a suitable stable/conservative firmware version that should be loaded onto cores.
CORE1.
Base ethernet MAC Address       : B0:FA:EB:E4:96:00
Motherboard assembly number     : 73-12530-08
Motherboard serial number       : FDO17031AQW
Model revision number           : A0
Motherboard revision number     : A0
Model number                    : WS-C3750X-24T-E
Daughterboard assembly number   : 800-32727-03
Daughterboard serial number     : FDO1703121Z
System serial number            : FDO1703Z0VC
Top Assembly Part Number        : 800-31327-07
Top Assembly Revision Number    : B0
Version ID                      : V04
CLEI Code Number                : COMJV00ARD
Hardware Board Revision Number  : 0x04
Switch Ports Model              SW Version            SW Image
*    1 30    WS-C3750X-24       15.2(1)E              C3750E-UNIVERSALK9-M
CORE2.
Base ethernet MAC Address       : 00:06:F6:54:06:80
Motherboard serial number       : FDO16510H0N
Daughterboard serial number     : FDO16510PQP
System serial number            : FDO1651P1K2
Version ID                      : V04
1 SOLUCIÓN ACEPTADA
Soluciones aceptadas
if this is helpful and it resolves your issue - can you mark as resolved so it will be useful for other members who have the same requirement?
BB
Ver la solución en mensaje original publicado
3 RESPUESTAS 3
balaji.bandi
As per cisco latest  you get is 15.2.4E10
read the realse notes :
https://www.cisco.com/c/en/us/support/ios-nx-os-software/ios-15-2e/products-release-notes-list.html
Note : the model you mentioned end of life, so you would not get any more updates and security patches.
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3560-x-series-switches/eos-eol-notice-c51-736139.html
BB
Thank you so much.
BB
