cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
Failover (HA) FTD 6.5.0.4
lilianamartinez
Hi ,
I know that the criteria do trigger the failover in FTD are the next :
  • More than 50% of the Snort instances on the active unit are down.
  • Disk space on the active unit is more than 90% full.
  • The no failover active command is run on the active unit or the failover active command is run on the standby unit.
  • The active unit has more failed interfaces than the standby unit.
  • Interface failure on the active device exceeds the threshold configured.
My question is , Can I add or edit this criteria ?
1 RESPUESTA 1
jlbohorquezm1
Hi Liliana,
I hope my answer will help you, check the attachment
Jose bohorquez
