annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
Visites
Compliment
Réponses
Enable ssh on cisco nexus 5k Switch for a public ip addresses
starsulaiman
Hello All,
I have been asked to enable ssh on cisco nexus 5k for a specific public ip addresses.
I have never done that before can someone provides me the configurations, please.
I have below configs, and will this be correct?
crypto key generate rsa usage-keys label ssh-key modulus 2048
feature ssh
interface g0
ip address 1.1.1.1 255.255.255.22
ssh version 2
ssh key rsa ssh-key
line ssh
exec-timeout 5 0
login local
username admin privilege 15 secret Admin123
enable secret Admin123
line vty 0 15
transport input ssh
write memory
show ssh
show ssh sessions
do i need to create ACL for it? if yes which interface should be applied?
can i have an example please?
many thank you
5 RÉPONSES 5
balaji.bandi
If you looking external IP address to access this device for SSH - make sure the Public IP able to reach the device IP (that is 1.1.1.1 - i am sure this is example IP not original one i guess ?)
below example for SSH to device :
ip access-list extended SSH_ACL
permit ip any host  x.x.x.x ( x.x.x.x is the Public IP address)
permit ip any x.x.x.x/24 (your network LAN)
line vty 0 15
access-class SSH_ACL in
transport input ssh
above config should work, make sure you also allow Internal Subnet (if not you only able to login using public IP)
BB
Hello Balaji,
thank you for the quick response.
a question please? dose below is my user lan network or my switch mgmt subnet network please
You Lan IP address from that range of subnet you looking to access switch using SSH.
permit ip  x.x.x.x/24 any
BB
M02@rt37
Hello @starsulaiman,
You have to enable SSH on a Cisco Nexus 5000 Series switch and  you should restrict access to specific public IP addresses.
# Restrict SSH to specific IP addresses using an ACL
ip access-list ssh-acl
10 permit ip x.x.x.x./yy any
20 permit ip x.x.x.x./yy any
30 deny ip any any
# Apply the ACL to the VTY lines
line vty 0 15
login local
transport input ssh
access-class ssh-acl in
I added an example ACL  to restrict SSH access to specific IP (source) addresses. Adjust the ACL entries based on your requirements. Apply this ACL to the VTY lines to restrict SSH access based on the ACL.
Best regards
1-dont use extended use standard acl
2- the standard acl IP is the IP form which you can access
3- you need
Login local
Or
Password xxxx
Login
To make vty accept ssh
MHM
