annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
Visites
Compliment
6
Réponses
ASA: replication of an Ethernet port - e.g. for WireShark/archiving
Joerg.Teske
Hello
        is there a possibility to perform a replication of a port on a Cisco ASA (e.g. to archive a copy of the data)?
The monitor command to be used on other Cisco equipment is not existing on the ASA.
Best regards
Jörg
6 RÉPONSES 6
balaji.bandi
What model of ASA - you can use Packet capture to send over to remote :
https://www.cisco.com/c/en/us/support/docs/security/asa-5500-x-series-next-generation-firewalls/118097-configure-asa-00.html
If the old model with Switch port on it, you can use command - switchport monitor
BB
Thank you for this fast answer. I use an ASA-5508-X.
Your link is explaining how to capture packages (mainly local in a buffer of the ASA) and to transfer this data later on.
What I search is to duplicate packages (no change of format, quasi realtime) and to send them to a second destination.
We use this for UDP packages. This is well working using a replicated port on a switch. The aim is to reduce the hardware using directly the ASA.
The switchport monitor command seems not to be available.
https://ultraconfig.com.au/blog/how-to-packet-capture-on-a-cisco-asa-firewall/
Check this' not real time is so hard to asa cpu.
Keep capture real-time as short ss possible.
MHM
Thank you. See above. This is not what we need. Sorry if I was not clear enough.
copy /pcap capture:pc-traffic-ssh tftp://<server-ip-address>
This copy pcap to server which then can show via wiresharke.
But I think you want real time monitoring.
I will check
MHM
Thank you, I'm not sure that the ASA is able to perform this replication - I found only the following for other Cisco elements:
https://www.it-connect.fr/configurer-le-port-mirroring-sous-cisco/
