M02@rt37
C1_B :
BGP neighbor is 192.168.1.1, remote AS 40001, internal link
BGP version 4, remote router ID 100.0.4.1
BGP state = Established, up for 00:04:03
Last read 00:00:16, last write 00:00:21, hold time is 180, keepalive interval is 60 seconds
Neighbor sessions:
1 active, is not multisession capable (disabled)
Neighbor capabilities:
Route refresh: advertised and received(new)
Four-octets ASN Capability: advertised and received
Address family IPv4 Unicast: advertised and received
Enhanced Refresh Capability: advertised and received
Multisession Capability:
Stateful switchover support enabled: NO for session 1
Message statistics:
InQ depth is 0
OutQ depth is 0
Sent Rcvd
Opens: 1 1
Notifications: 0 0
Updates: 2 2
Keepalives: 6 6
Route Refresh: 0 0
Total: 9 11
Do log neighbor state changes (via global configuration)
Default minimum time between advertisement runs is 0 seconds
For address family: IPv4 Unicast
Session: 192.168.1.1
BGP table version 3, neighbor version 3/0
Output queue size : 0
Index 1, Advertise bit 0
1 update-group member
Slow-peer detection is disabled
Slow-peer split-update-group dynamic is disabled
Sent Rcvd
Prefix activity: ---- ----
Prefixes Current: 2 1 (Consumes 80 bytes)
Prefixes Total: 2 1
Implicit Withdraw: 0 0
Explicit Withdraw: 0 0
Used as bestpath: n/a 0
Used as multipath: n/a 0
Outbound Inbound
Local Policy Denied Prefixes: -------- -------
Total: 0 0
Number of NLRIs in the update sent: max 2, min 0
Last detected as dynamic slow peer: never
Dynamic slow peer recovered: never
Refresh Epoch: 2
Last Sent Refresh Start-of-rib: never
Last Sent Refresh End-of-rib: never
Last Received Refresh Start-of-rib: 00:04:03
Last Received Refresh End-of-rib: 00:04:03
Refresh-In took 0 seconds
Sent Rcvd
Refresh activity: ---- ----
Refresh Start-of-RIB 0 1
Refresh End-of-RIB 0 1
Address tracking is enabled, the RIB does have a route to 192.168.1.1
Route to peer address reachability Up: 1; Down: 0
Last notification 00:04:13
Connections established 1; dropped 0
Last reset never
Interface associated: (none) (peering address in same link)
Transport(tcp) path-mtu-discovery is enabled
Graceful-Restart is disabled
SSO is disabled
Connection state is ESTAB, I/O status: 1, unread input bytes: 0
Connection is ECN Disabled, Mininum incoming TTL 0, Outgoing TTL 255
Local host: 192.168.1.2, Local port: 179
Foreign host: 192.168.1.1, Foreign port: 64469
Connection tableid (VRF): 0
Maximum output segment queue size: 50
Enqueued packets for retransmit: 0, input: 0 mis-ordered: 0 (0 bytes)
Event Timers (current time is 0x468C94):
Timer Starts Wakeups Next
Retrans 7 0 0x0
TimeWait 0 0 0x0
AckHold 8 5 0x0
SendWnd 0 0 0x0
KeepAlive 0 0 0x0
GiveUp 0 0 0x0
PmtuAger 0 0 0x0
DeadWait 0 0 0x0
Linger 0 0 0x0
ProcessQ 0 0 0x0
iss: 4062226446 snduna: 4062226700 sndnxt: 4062226700
irs: 1969102436 rcvnxt: 1969102732
sndwnd: 16131 scale: 0 maxrcvwnd: 16384
rcvwnd: 16089 scale: 0 delrcvwnd: 295
SRTT: 607 ms, RTTO: 2949 ms, RTV: 2342 ms, KRTT: 0 ms
minRTT: 0 ms, maxRTT: 1000 ms, ACK hold: 200 ms
uptime: 243936 ms, Sent idletime: 16384 ms, Receive idletime: 16584 ms
Status Flags: passive open, gen tcbs
Option Flags: nagle, path mtu capable
IP Precedence value : 6
Datagrams (max data segment is 1460 bytes):
Rcvd: 18 (out of order: 0), with data: 10, total data bytes: 295
Sent: 17 (retransmit: 0, fastretransmit: 0, partialack: 0, Second Congestion: 0), with data: 8, total data bytes: 253
Packets received in fast path: 0, fast processed: 0, slow path: 0
fast lock acquisition failures: 0, slow path: 0
TCP Semaphore 0x106B5C24 FREE
BGP neighbor is 213.111.0.2, remote AS 40002, external link
BGP version 4, remote router ID 0.0.0.0
BGP state = Idle
Neighbor sessions:
0 active, is not multisession capable (disabled)
Default minimum time between advertisement runs is 30 seconds
BGP table version 3, neighbor version 1/3
Index 0, Advertise bit 0
Sent Rcvd
Prefixes Current: 0 0
Prefixes Total: 0 0
Outbound Inbound
Total: 0 0
Number of NLRIs in the update sent: max 0, min 0
Refresh Epoch: 1
Last Received Refresh Start-of-rib: never
Last Received Refresh End-of-rib: never
Sent Rcvd
Refresh Start-of-RIB 0 0
Refresh End-of-RIB 0 0
Address tracking is enabled, the RIB does have a route to 213.111.0.2
Last notification 00:17:36
Connections established 0; dropped 0
Last reset never
External BGP neighbor configured for connected checks (single-hop no-disable-connected-check)
Interface associated: (none) (peering address NOT in same link)
SSO is disabled
No active TCP connection
C2_B :
BGP neighbor is 192.168.2.2, remote AS 40002, internal link
BGP version 4, remote router ID 200.0.1.1
BGP state = Established, up for 00:01:24
Last read 00:00:26, last write 00:00:14, hold time is 180, keepalive interval is 60 seconds
Neighbor sessions:
Message statistics:
InQ depth is 0
OutQ depth is 0
Sent Rcvd
Opens: 1 1
Notifications: 0 0
Updates: 2 2
Keepalives: 2 3
Route Refresh: 0 0
Total: 5 6
Session: 192.168.2.2
Index 2, Advertise bit 0
2 update-group member
Sent Rcvd
Prefixes Total: 2 1
Outbound Inbound
Total: 0 0
Refresh Epoch: 1
Sent Rcvd
Address tracking is enabled, the RIB does have a route to 192.168.2.2
Connections established 2; dropped 1
Last reset 00:01:25, due to Router ID changed of session 1
Local host: 192.168.2.1, Local port: 31304
Foreign host: 192.168.2.2, Foreign port: 179
Event Timers (current time is 0xD657A20):
Retrans 4 0 0x0
TimeWait 0 0 0x0
AckHold 4 1 0x0
SendWnd 0 0 0x0
KeepAlive 0 0 0x0
GiveUp 0 0 0x0
PmtuAger 1 0 0xD6D56C4
DeadWait 0 0 0x0
Linger 0 0 0x0
ProcessQ 0 0 0x0
iss: 158484237 snduna: 158484415 sndnxt: 158484415
irs: 498479643 rcvnxt: 498479836
sndwnd: 16207 scale: 0 maxrcvwnd: 16384
rcvwnd: 16192 scale: 0 delrcvwnd: 192
SRTT: 413 ms, RTTO: 3205 ms, RTV: 2792 ms, KRTT: 0 ms
uptime: 84764 ms, Sent idletime: 14108 ms, Receive idletime: 14108 ms
Status Flags: active open
Rcvd: 8 (out of order: 0), with data: 5, total data bytes: 192
Sent: 9 (retransmit: 0, fastretransmit: 0, partialack: 0, Second Congestion: 0), with data: 4, total data bytes: 177
TCP Semaphore 0x31D2BB84 FREE
BGP neighbor is 213.111.0.1, remote AS 40001, external link
BGP state = Idle
Neighbor sessions:
Sent Rcvd
Prefixes Total: 0 0
Outbound Inbound
Total: 0 0
Refresh Epoch: 1
Sent Rcvd
Address tracking is enabled, the RIB does have a route to 213.111.0.1
Last reset never
