annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
Visites
Compliment
51
Réponses
Relation BGPne marche pas
Baptiste
Bonjour,
Je souhaite faire une infra BGP avec RPKI voici l'infra.
Le routeur C1_B arrive a pinger le 213.111.0.2 mais pas la 192.168.2.1.
Voici la conf bgp du routeur c1_B
router bgp 40001
bgp log-neighbor-changes
bgp rpki server tcp 192.168.102.39 port 3323 refresh 600
neighbor 192.168.1.1 remote-as 40001
neighbor 192.168.102.39 remote-as 40001
neighbor 213.111.0.2 remote-as 40002
neighbor 213.111.0.2 update-source GigabitEthernet0/3
address-family ipv4
network 192.168.1.0
network 213.111.0.0
neighbor 192.168.1.1 activate
neighbor 192.168.1.1 route-map rtmp-rpki in
neighbor 192.168.102.39 activate
neighbor 192.168.102.39 route-map rtmp-rpki in
neighbor 213.111.0.2 activate
exit-address-family
Conf routeur BGP C2_B :
router bgp 40002
network 192.168.2.0
network 213.111.0.0 mask 255.255.192.0
neighbor 192.168.2.2 remote-as 40002
neighbor 213.111.0.1 remote-as 40001
neighbor 213.111.0.1 update-source GigabitEthernet0/0
Merci d'avance
Baptiste
51 RÉPONSES 51
Baptiste
M02@rt37
C2_B :
C2_B(config)#do sh ip bgp neighbors
BGP neighbor is 192.168.2.2,  remote AS 40002, internal link
  BGP version 4, remote router ID 200.0.1.1
  BGP state = Established, up for 00:01:24
  Last read 00:00:26, last write 00:00:14, hold time is 180, keepalive interval is 60 seconds
  Neighbor sessions:
    1 active, is not multisession capable (disabled)
  Neighbor capabilities:
    Route refresh: advertised and received(new)
    Four-octets ASN Capability: advertised and received
    Address family IPv4 Unicast: advertised and received
    Enhanced Refresh Capability: advertised and received
    Multisession Capability:
    Stateful switchover support enabled: NO for session 1
  Message statistics:
    InQ depth is 0
    OutQ depth is 0
                         Sent       Rcvd
    Opens:                  1          1
    Notifications:          0          0
    Updates:                2          2
    Keepalives:             2          3
    Route Refresh:          0          0
    Total:                  5          6
  Default minimum time between advertisement runs is 0 seconds
 For address family: IPv4 Unicast
  Session: 192.168.2.2
  BGP table version 3, neighbor version 3/0
  Output queue size : 0
  Index 2, Advertise bit 0
  2 update-group member
  Slow-peer detection is disabled
  Slow-peer split-update-group dynamic is disabled
  Interface associated: (none)
                                 Sent       Rcvd
  Prefix activity:               ----       ----
    Prefixes Current:               2          1 (Consumes 80 bytes)
    Prefixes Total:                 2          1
    Implicit Withdraw:              0          0
    Explicit Withdraw:              0          0
    Used as bestpath:             n/a          0
    Used as multipath:            n/a          0
                                   Outbound    Inbound
  Local Policy Denied Prefixes:    --------    -------
    Total:                                0          0
  Number of NLRIs in the update sent: max 2, min 0
  Last detected as dynamic slow peer: never
  Dynamic slow peer recovered: never
  Refresh Epoch: 1
  Last Sent Refresh Start-of-rib: never
  Last Sent Refresh End-of-rib: never
  Last Received Refresh Start-of-rib: never
  Last Received Refresh End-of-rib: never
       Sent   Rcvd
Refresh activity:        ----   ----
  Refresh Start-of-RIB          0          0
  Refresh End-of-RIB            0          0
  Address tracking is enabled, the RIB does have a route to 192.168.2.2
  Connections established 2; dropped 1
  Last reset 00:01:25, due to Router ID changed of session 1
  Transport(tcp) path-mtu-discovery is enabled
  Graceful-Restart is disabled
Connection state is ESTAB, I/O status: 1, unread input bytes: 0
Connection is ECN Disabled, Mininum incoming TTL 0, Outgoing TTL 255
Local host: 192.168.2.1, Local port: 31304
Foreign host: 192.168.2.2, Foreign port: 179
Connection tableid (VRF): 0
Maximum output segment queue size: 50
Enqueued packets for retransmit: 0, input: 0  mis-ordered: 0 (0 bytes)
Event Timers (current time is 0xD657A20):
Timer          Starts    Wakeups            Next
Retrans             4          0             0x0
TimeWait            0          0             0x0
AckHold             4          1             0x0
SendWnd             0          0             0x0
KeepAlive           0          0             0x0
GiveUp              0          0             0x0
PmtuAger            1          0       0xD6D56C4
DeadWait            0          0             0x0
Linger              0          0             0x0
ProcessQ            0          0             0x0
iss:  158484237  snduna:  158484415  sndnxt:  158484415
irs:  498479643  rcvnxt:  498479836
sndwnd:  16207  scale:      0  maxrcvwnd:  16384
rcvwnd:  16192  scale:      0  delrcvwnd:    192
SRTT: 413 ms, RTTO: 3205 ms, RTV: 2792 ms, KRTT: 0 ms
minRTT: 0 ms, maxRTT: 1000 ms, ACK hold: 200 ms
uptime: 84764 ms, Sent idletime: 14108 ms, Receive idletime: 14108 ms
Status Flags: active open
Option Flags: nagle, path mtu capable
IP Precedence value : 6
Datagrams (max data segment is 1460 bytes):
Rcvd: 8 (out of order: 0), with data: 5, total data bytes: 192
Sent: 9 (retransmit: 0, fastretransmit: 0, partialack: 0, Second Congestion: 0), with data: 4, total data bytes: 177
 Packets received in fast path: 0, fast processed: 0, slow path: 0
 fast lock acquisition failures: 0, slow path: 0
TCP Semaphore      0x31D2BB84  FREE
BGP neighbor is 213.111.0.1,  remote AS 40001, external link
  BGP version 4, remote router ID 0.0.0.0
  BGP state = Idle
  Neighbor sessions:
    0 active, is not multisession capable (disabled)
  Default minimum time between advertisement runs is 30 seconds
  BGP table version 3, neighbor version 1/3
  Index 0, Advertise bit 0
                                 Sent       Rcvd
    Prefixes Current:               0          0
    Prefixes Total:                 0          0
                                   Outbound    Inbound
    Total:                                0          0
  Number of NLRIs in the update sent: max 0, min 0
  Refresh Epoch: 1
       Sent   Rcvd
  Address tracking is enabled, the RIB does have a route to 213.111.0.1
  Connections established 0; dropped 0
  Last reset never
  No active TCP connection
What issue here can you make your post in English?
@MHM Cisco World
I want to make a BGP infra with RPKI.
I would like to make these two AS communicate but the router C1_B does not manage to know the network 192.168.2.0/24 and conversely with the router C2_B.
Router C1_B pings 213.111.0.2 but not 192.168.2.1.
Here is the bgp configuration of router C1_B:
router bgp 40001
 neighbor 213.111.0.2 update-source GigabitEthernet0/0
 address-family ipv4
  network 192.168.1.0
  network 213.111.0.0
 exit-address-family
Here is the bgp configuration of router C2_B:
router bgp 40002
 network 192.168.2.0
 network 213.111.0.0
 neighbor 213.111.0.1 update-source GigabitEthernet0/1
Here is the error message from the C2_B routeut:
*Sep 24 16:08:51.248 : %BGP-5-NBR_RESET : Neighbor 213.111.0.1 active reset (Peer closed the session)
*Sep 24 16:08:51.248 : %BGP_SESSION-5-ADJCHANGE : neighbor 213.111.0.1 IPv4 Unicast topology base removed from session Peer closed the session
thank you in advance for your help
Baptiste
When we do a sh ip route on the routeut C1_B we can see that it can't learn the network 192.168.2.0.
ip ro
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
a - application route
+ - replicated route, % - next hop override, p - overrides from PfR
Gateway of last resort is not set
100.0.0.0/32 is subnetted, 3 subnets
C 100.0.3.1 is directly connected, Loopback0
O 100.0.4.1 [110/2] via 192.168.1.1, 03:27:46, Vlan10
O 100.0.5.1 [110/2] via 192.168.1.3, 03:27:46, Vlan10
192.168.1.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.1.0/24 is directly connected, Vlan10
L 192.168.1.2/32 is directly connected, Vlan10
213.111.0.0/24 is variably subnetted, 2 subnets, 2 masks
C 213.111.0.0/24 is directly connected, Vlan20
L 213.111.0.1/32 is directly connected, Vlan20
@Baptiste ,
Ajoute
Best regards
Baptiste
Voici la configuration qui marche :
router bgp 40001
 address-family ipv4
  network 192.168.1.0
  network 213.111.0.0
  neighbor 192.168.102.39 route-map rpki in
 exit-address-family
Je suis heureuse de constater que vous avez réussi ! Félicitations à tous les trois...
