cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
9
Comentarios
KarenObando2933
Ayuda!! Tengo esta topologia, en la que le he configurado Etherchannel pagp y lacp, VTP, cree las vlans, DHCP, HSRP y mi pc's no pueden hacer ping en la red interna entre ellas. Ya revise la configuración y no se que cual podria ser el fallo.
Muchas gracias por su ayuda!!!
Swich 3560
ip dhcp excluded-address 10.0.0.1
ip dhcp excluded-address 10.0.0.2
ip dhcp excluded-address 10.0.1.254
ip dhcp excluded-address 10.0.1.65
ip dhcp excluded-address 10.0.1.67
ip dhcp excluded-address 10.0.1.126
ip dhcp excluded-address 10.0.1.129
ip dhcp excluded-address 10.0.1.130
ip dhcp excluded-address 10.0.1.190
ip dhcp excluded-address 10.0.1.193
ip dhcp excluded-address 10.0.1.194
ip dhcp excluded-address 10.0.1.222
ip dhcp excluded-address 10.0.1.225
ip dhcp excluded-address 10.0.1.226
ip dhcp excluded-address 10.0.2.254
ip dhcp excluded-address 10.0.2.1
ip dhcp excluded-address 10.0.2.14
ip dhcp excluded-address 10.0.2.17
ip dhcp excluded-address 10.0.2.18
ip dhcp excluded-address 10.0.2.30
ip dhcp excluded-address 10.0.2.33
ip dhcp excluded-address 10.0.2.34
ip dhcp excluded-address 10.0.2.46
ip dhcp excluded-address 10.0.2.49
ip dhcp excluded-address 10.0.2.50
ip dhcp excluded-address 10.0.2.62
ip dhcp excluded-address 10.0.2.65
ip dhcp excluded-address 10.0.2.66
ip dhcp excluded-address 10.0.2.77
ip dhcp excluded-address 10.0.2.81
ip dhcp excluded-address 10.0.2.82
ip dhcp excluded-address 10.0.2.94
ip dhcp pool Produccion
network 10.0.0.0 255.255.255.0
default-router 10.0.1.254
dns-server 172.16.1.4
ip dhcp pool Vlan-video
network 10.0.1.64 255.255.255.192
default-router 10.0.1.126
ip dhcp pool Editor-de-Pelicula
network 10.0.1.128 255.255.255.192
default-router 10.0.1.190
ip dhcp pool Wifi-Invitados
network 10.0.1.192 255.255.255.224
default-router 10.0.1.222
ip dhcp pool TI-Informatica
network 10.0.1.224 255.255.255.224
default-router 10.0.2.254
ip dhcp pool RRHH-Recepcion
network 10.0.2.0 255.255.255.240
default-router 10.0.2.14
ip dhcp pool Contabilidad
network 10.0.2.16 255.255.255.240
default-router 10.0.2.30
ip dhcp pool Mercadeo
network 10.0.2.32 255.255.255.240
default-router 10.0.2.46
ip dhcp pool Gerencia
network 10.0.2.48 255.255.255.240
default-router 10.0.2.62
ip dhcp pool Administracion
network 10.0.2.64 255.255.255.240
default-router 10.0.2.77
ip dhcp pool Servidor
network 10.0.2.80 255.255.255.240
default-router 10.0.2.94
ip routing
spanning-tree mode rapid-pvst
spanning-tree vlan 5,10,30,40,50 priority 24576
spanning-tree vlan 60,70,90,100,120 priority 28672
interface Port-channel1
switchport mode trunk
interface Port-channel2
interface Port-channel3
interface Port-channel7
interface Port-channel8
interface FastEthernet0/1
channel-group 7 mode auto
interface FastEthernet0/2
interface FastEthernet0/3
channel-group 8 mode desirable
interface FastEthernet0/4
interface FastEthernet0/5
channel-group 1 mode active
interface FastEthernet0/6
interface FastEthernet0/7
channel-group 2 mode active
interface FastEthernet0/8
interface FastEthernet0/9
channel-group 3 mode active
interface FastEthernet0/10
interface Vlan10
mac-address 0040.0bb8.9401
ip address 10.0.0.1 255.255.255.0
standby 10 ip 10.0.0.254
standby 10 priority 200
standby 10 preempt
interface Vlan30
mac-address 0040.0bb8.9402
ip address 10.0.1.65 255.255.255.192
standby 30 ip 10.0.1.126
standby 30 priority 200
standby 30 preempt
interface Vlan40
mac-address 0040.0bb8.9403
ip address 10.0.1.129 255.255.255.192
standby 40 ip 10.0.1.190
standby 40 priority 200
standby 40 preempt
interface Vlan50
mac-address 0040.0bb8.9404
ip address 10.0.1.193 255.255.255.224
standby 50 ip 10.0.1.222
standby 50 priority 110
standby 50 preempt
interface Vlan60
mac-address 0040.0bb8.9405
ip address 10.0.1.225 255.255.255.224
standby 60 ip 10.0.1.254
standby 60 priority 110
standby 60 preempt
interface Vlan70
mac-address 0040.0bb8.9406
ip address 10.0.2.1 255.255.255.240
standby 70 ip 10.0.2.30
standby 70 priority 110
standby 70 preempt
interface Vlan80
mac-address 0040.0bb8.9407
ip address 10.0.2.17 255.255.255.240
standby 80 preempt
interface Vlan90
mac-address 0040.0bb8.9408
ip address 10.0.2.33 255.255.255.240
standby 90 ip 10.0.2.46
standby 90 priority 110
standby 90 preempt
interface Vlan100
mac-address 0040.0bb8.9409
ip address 10.0.2.49 255.255.255.240
standby 100 ip 10.0.2.62
standby 100 priority 110
standby 100 preempt
interface Vlan120
mac-address 0040.0bb8.940a
ip address 10.0.2.81 255.255.255.240
standby 120 ip 10.0.2.94
standby 120 priority 110
standby 120 preempt
Comentarios
Julio E. Moisa
Hola,
Asumiendo que tu configuracion este bien, seria bueno que nos compartas el archivo de packet tracer e indicarnos de donde a donde no puedes hacer ping.
Saludos
Diana Karolina Rojas
Buenas tardes estimada,
Para comenzar creo que tienes un problema en la distribución de tus IPs. Para poner un ejemplo, tu tienes este pool DHCP:
El el cual todos los equipos dentro de la red 10.0.0.0/24 van a tener a esta ip como gateway -> 10.0.1.254, pero entonces tienes lo siguiente en la interfaz vlan:
interface Vlan10
standby 10 preempt
Le estas diciendo al router que el gateway de los equipos de la red 10.0.0.0/24 es la IP 10.0.0.254, que es distinta de la IP 10.0.1.254 que tienes mas arriba... Me parece que tienes que revisar todos los pools y contrastarlos con lo que tienen tus SVIs para ver si estas colocando los gateways correctamente, porque de otro modo tus maquinas están yendo a gateways que no existen.
***Por favor no olvides calificar las respuestas útiles, tu calificación promueve nuestra participación.***
Saludos,
KarenObando2933
@Diana Karolina Rojas  si tienes razon, ya lo cambie y aun sigo presentando el problema de que no puedo hacer ping.
¿Revisaste todos los pools DHCP y todas las SVIs? porque si bien yo encontré el error en la primera vlan no revisé el resto de la configuración, por lo que pueden haber errores en varias partes. Además tengo las siguientes preguntas:
1. ¿Todas tus maquinas llegan correctamente a su gateway?
2. ¿Todas las SVIs estan UP/UP?
3. ¿Todas las maquinas están tomando IP correctamente?
A propósito te recomendaría enviar la configuraciones de ambos equipos completas adjuntas en un archivo txt, porque la que aparece en la discusión esta cortada.
KarenObando2933
@Julio E. Moisa
Te comparto el achivo en one drive ya que a la hora de subirlo, me emite un error.
e=fz4w3bhttps://1drv.ms/u/s!ArQKYZLXrq_FgldgKphk_7TqU-JX?e=fz4w3b
KarenObando2933
Revise todas las DHCP y al parecer todas estan bien. Y te adjunto  la captura del estado de las vlan en ambos switch estan up.
El problema que tengo desde el principio es que entre ellas no hace ping ni al gateway. Ya al rato una que otra si hace ping al gateway pero no todas.
Y si correcto todas estan recibiendo ip mediante DHCP correctamente.
Muchas gracias.
Karen buenos días,
Perdóname pero insisto, tu problema es de distribución de IPs. Acabo de abrir tu archivo de packet tracer e hice una prueba con la PC RRHH/Recepcion (Vlan 70), esta maquina por DHCP esta recibiendo como gateway la IP 10.0.2.14, pero esta IP no es ninguna IP ni física ni virtual (HRSP) en ninguno de tus switches L3, por lo que esta maquina esta enviando tráfico a un gateway que no existe. Debes revisar vlan por vlan qué esta entregando tu DHCP y ver si tienes un gateway correspondiente a lo que estas colocando en tus pools, es exactamente el mismo problema que tenías es la vlan 10, definitivamente este es el problema que estas teniendo.
Saludos,
Julio E. Moisa
Hola,
He revisado algunas de las PC/Laptops pero no tienen direccion IP o un DHCP en routers.
Saludos
KarenObando2933
Tienes toda la razon, ya lo revise cambien los errores y volvi a empezar con la configuración y ya todo me esta funcionando perfectamente.
Muchisimas Gracias.
Vamos a comenzar
