02-28-2025 08:00 AM
Hello everyone! Here are the release notes for our most recent updates to Duo.
Public release notes are published on the Customer Community every other Friday, the day after the D-release is completely rolled out to commercial deployments. You can subscribe to notifications for new release notes by following the process described here. Check the Duo cloud service release version for your Duo account from the Duo Admin Panel.
If you have any questions about these changes, please comment below.
Review the Guide to Duo End-of-Life and End-of-Support Plans. This guide provides an up-to-date list of current and past end-of-life plans for Duo products.
The Duo LDAP cloud service used to provide two-factor authentication via direct LDAPS connection for Cisco ASA, Juniper Networks Secure Access, or Pulse Secure Connect Secure SSL VPN logins reached end of life on February 20, 2025. See more details about this end-of-life plan in the Duo Knowledge Base.
Five existing SSO applications with enhanced attribute support so that name ID attribute shows as custom attribute
Os password less is not working i dont have the enrollment prompt for it during windows sign on.
The Verified Duo Push for Windows logons code is too small leading to confusion for end users. Anyone who agrees, please log in to the DUO support portal and create a feature request case. If there are enough requests, perhaps this will get improved soon. Thanks!
@medina-monkey51120 SOrry you're having issues. Please go through these articles in the Duo Knowledge Base to help troubleshoot:
https://help.duo.com/s/article/9088
https://help.duo.com/s/article/9209
If you still have issues you may want to contact Duo Support if you are eligible.
I have the following problem when updating the DUO Agent for windows Logon (v5.0.0):
When executing the new .exe file, the VM restarts immediately (without warning). When I restarted the .exe, I received the following error message:
Error Starting Setup: Error 0 occurred when creating secure temporary directory.
This article https://help.duo.com/s/article/8827?language=en_US pointed out that you have to delete a temporary folder beforehand. This then also worked. Is this a known problem and will there be a fix for it? Or do I simply have to delete the temporary folder every time?
Have you tried the MSI installer as a workaround instead of EXE? We successfully updated all our servers to Duo for Windows 5.0.0 using the MSI with /quiet /qn /norestart parameters and didn't experience any unexpected reboots.
We do understand an unexpected reboot may be disruptive. It is hard to predict whether a given system will require a reboot or not, as it depends on the state of Windows and other installations/applications on the same system or files in use at the time of install.
If interruptions are a concern it is a good ideal to plan updates during a maintenance window where servers can be rebooted if needed.
I have made the updates using GPO and msi package. It works without any problems. I have to restart the VMs to take effect, but that's not a big deal. However, it would be nice if it also works with the exe without problems.
Thanks @nlev for the hint.
