App Activation error: Device association is missing with a USB device.
arun1587
Frequent Visitor
Frequent Visitor
I get this error while trying to activate a docker app on iox. The app basically tries to communicate to the serial USB device connected to the router. I followed the instructions from https://developer.cisco.com/docs/iox/#!sample/universal-serial-bus-usb-usage-in-the-app
info about my setup:
os version: 1.6.3
<<<<<< package.yaml file >>>>>
app:
  cpuarch: "x86_64"
  type: docker
  resources:
    profile: c1.large
    network:
        interface-name: eth0
    devices:
        type: usbdev
        label: HOST_DEV1
        function: serial
        vendorID: "0483"
        productID: "5740"
        mandatory: True
<<<<<< lsusb from the container console >>>>
# lsusb
Bus 002 Device 003: ID 0483:5740
Bus 001 Device 001: ID 1d6b:0002
Bus 002 Device 001: ID 1d6b:0001
<<<<< dmesg output from the container console >>>>
usb 2-1: new full-speed USB device number 3 using ohci-pci
cdc_acm 2-1:1.0: ttyACM0: USB ACM device
<<< ioxclient platform device list  snippet >>>>
"usbdev": [
   "available": true,
   "bus": "2",
   "dev": "3",
   "device_class": "02\n",
   "device_id": "/dev/bus/usb/002/003",
   "device_name": null,
   "device_path": "/sys/devices/pci0000:00/0000:00:0a.0/usb2/2-1",
   "generic_params": {},
   "is_generic": false,
   "is_storage": false,
   "pid": "5740",
   "port": null,
   "storage_params": null,
   "support_fstype": [
    "vfat"
   "type": "usbdev",
   "used_by": null,
   "vid": "0483"
<<<<<<</dev from the container>>>>>>>>
# ls -lrt /dev/
total 0
crw-rw-rw-    1 root root        1, 5 Jun 14 14:21 zero
crw-rw-rw-    1 root root        1, 9 Jun 14 14:21 urandom
lrwxrwxrwx    1 root root            10 Jun 14 14:21 tty1 -> /dev/pts/0
crw-rw-rw-    1 root root        5, 0 Jun 14 14:21 tty
lrwxrwxrwx    1 root root            15 Jun 14 14:21 stdout -> /proc/self/fd/1
lrwxrwxrwx    1 root root            15 Jun 14 14:21 stdin -> /proc/self/fd/0
lrwxrwxrwx    1 root root            15 Jun 14 14:21 stderr -> /proc/self/fd/2
crw-rw-rw-    1 root root        1, 8 Jun 14 14:21 random
drwxr-xr-x    2 root root             0 Jun 14 14:21 pts
crw-rw-rw-    1 root root        5, 2 Jun 14 14:21 ptmx
crw-rw-rw-    1 root root        1, 3 Jun 14 14:21 null
drwxr-xr-x    2 nobody nobody          60 Jun 14 14:21 net
crw-rw-rw-    1 root root        1, 7 Jun 14 14:21 full
lrwxrwxrwx    1 root root            13 Jun 14 14:21 fd -> /proc/self/fd
lrwxrwxrwx    1 root root            10 Jun 14 14:21 console -> /dev/pts/0
the app ran locally on my PC fine with the following command;
docker run -t -i --device=/dev/ttyACM0 test-app"
could you please let me know what is still missing?
thanks,
13 Replies 13
Geevarghese Cheria
Hi Arun,
Please check these related urls
Thanks and Regards,
Geevarghese
Hi Geevarghese,
I followed both the links that you pasted and I shared the error along with my configurations and output.
It would be great if you can help me looking at those configuration and output and let me know if there is something missing?
The USB device is also not listed by the localmanager.
thanks,
Arun
Please refer to https://developer.cisco.com/docs/iox/#!usb-device-usage/universal-serial-bus-usb and https://developer.cisco.com/docs/iox/#!sample.
And please note only USB storage and serial devices are supported for Cisco IOx.
Hello Steve,
I followed the link that you have shared.  I've shared my package file and other outputs at the beginning of the thread.
Yes, I used a lorawan modem that can be enumerated as usb serial device.
I couldn't notice any obvious thing that is wrong in my configuration.
could you please let me know what can make a usb_serial device not to be listed by the localmanager? May be this could help further debugging the issue.
thanks,
I remember I have similar problem to use USB long time ago, don't remember what exactly was the error.
I remember I have to change one or two of following in yaml file, either product id , vendor id or device id or the combination of them.
Just FYI, don't if it helps.
    devices:
        type: usbdev
        label: HOST_DEV
        usage: Needs usb storage device to persist data
        function: storage
        mandatory: True
        mount-point: /extra/storage/
        device-directory-to-mount: /home/root/testUSB
        vendorID: "067b"
        productID: "2517"
  "devices": [{"type": "usbdev", "label": "HOST_DEV", "device-id": "/dev/bus/usb/001/006", "vid":"067b", "pid":"2517"}]
arun1587
Frequent Visitor
Frequent Visitor
I use the values of vid, pid of the device from the output of "ioxclient platform device list" and also I'm using the device as serial usb device.
I still see the USB device as undefined in ioxLocalManager.
output of "ioxclient platform device list" >>>>
"usbdev": [
   "available": true,
   "bus": "2",
   "dev": "4",
   "device_id": "/dev/bus/usb/002/004",
   "pid": "5740",
   "port": null,
   "support_fstype": [
    "vfat"
   "type": "usbdev",
   "used_by": null,
   "vid": "0483"
package.yaml >>>>
app:
  cpuarch: "x86_64"
  type: docker
  resources:
    profile: c1.large
    network:
    devices:
        type: usbdev
        label: HOST_DEV1
        function: serial
        vendorID: "0483"
        productID: "5740"
        mandatory: True
Have you checked this doc see if the USB is recognized and mounted properly?
https://www.cisco.com/c/en/us/td/docs/routers/access/800/829/software/configuration/guide/b_IR800config/guestos.html#con…
I ioxclient platform output looks like this:
"usbdev": [
   "available": true,
   "bus": "1",
   "dev": "2",
   "device_class": "00\n",
   "device_id": "/dev/bus/usb/001/002",
   "device_name": "/dev/sdc1",
   "device_path": "/sys/devices/pci0000:00/0000:00:09.0/usb1/1-1",
   "generic_params": null,
   "is_storage": true,
   "pid": "2517",
   "port": null,
   "storage_params": {
    "fs_label": "CORSAIR",
    "fs_uuid": "1C2E-5359",
    "fstype": "vfat",
    "model": "USB_Mass_Storage_Device",
    "mount_point": null,
    "vendor": "Prolific_Technology_Inc."
   "support_fstype": [
    "vfat"
   "type": "usbdev",
   "used_by": null,
   "vid": "067b"
"usbport": [
   "available": true,
   "device_id": "usb2",
   "device_name": "usb-serial",
   "ds_dids": [],
   "support_fstype": [
    "vfat"
   "type": "usbport",
   "used_by": null
   "available": true,
   "device_id": "usb1",
   "device_name": "usb-ports",
   "ds_dids": [
   "pbus": "00",
   "pdomain": "0000",
   "pfunc": "0",
   "pslot": "09",
   "support_fstype": [
    "vfat"
   "type": "usbport",
   "used_by": null
arun1587
Frequent Visitor
Frequent Visitor
yep,  I could see it in lsusb and also in /dev
root@Cisco829-GOS-1:~# ls -lrt /dev/ttyACM0
crw-rw---- 1 root dialout 166, 0 Jul  6 09:21 /dev/ttyACM0
root@Cisco829-GOS-1:~# lsusb
Bus 002 Device 005: ID 0483:5740
Have you tried to activate it from ioxclient ? (with debug)
arun1587
Frequent Visitor
Frequent Visitor
yes, I tried it with ioxclient and wasn't a successful try.
I will post the logs from debug here, shortly.
arun1587
Frequent Visitor
Frequent Visitor
yes, I tried it with IOX client and wasn't a successful try.
$ cat activation_storage.json
"resources": {
"profile": "c1.large",
"cpu": "600",
"memory": "256",
"disk": "20",
"network": [{"interface-name": "eth0", "network-name": "iox-bridge0"}],
"devices": [{"type": "usbdev", "label": "HOST_DEV1", "device-id": "/dev/bus/usb/002/004", "vid":"0483", "pid":"5740", "device-name":"lorawan"}]
ioxclient application activate 1 --payload activation_storage.json
\Currently active profile : tcp-app-test
Command Name: application-activate
Payload file : activation_storage.json. Will pass it as application/json in request body..
Saving current configuration
Could not complete your command : Error. Server returned 500
"description": "App Activation error: USB device not available for application use, but app has a mandatory dependency",
"errorcode": -1021,
"message": "Error while changing app state"
acklio@acklio:~/workspace/src/bitbucket.org/acklio/tcp-app$
 "device-name" - I couldn't find any definition for this field in https://developer.cisco.com/docs/iox/#!usb-device-usage/universal-serial-bus-usb. but it seems to be  a mandatory field because without which I get the following error.
ioxclient application activate test --payload activation_storage.json
2018/07/26 10:08:03 POST /iox/api/v2/hosting/apps/test/state?action=activate HTTP/1.1
Host: 192.168.1.112:8443
Content-Type: application/json
X-Token-Id: dd55ab15-c593-4367-8129-5467c445e8fb
"resources": {
"cpu": "600",
"memory": "256",
"disk": "20",
"devices": [{"type": "usbdev", "label": "/dev/ttyACM0", "device-id": "/dev/bus/usb/002/002", "vid":"0483", "pid":"5740"}]
"description": "App Activation error: 'device-name'",
"errorcode": -1021,
