C9500 IOx container app on customer vrf (or vlan)
-magesh-
C9500 does not have the AppGigabitEthernet interface for IOx apps, so it is slightly different from C9300.
All the examples I have found on Cisco documents/blogs relating to IOx containers on C9500 only point to using management network for connectivity.
I have upgraded the C9500 to ios 17.3.1 and managed to set up the Virtual Port Group on a custom vrf. The issue I am facing is that every alternate packet (ping test) is dropped. Here are my configs:
interface VirtualPortGroup0
 ip vrf forwarding D1
 ip address 192.168.2.1 255.255.255.0
app-hosting appid networktest
 app-vnic gateway0 virtualportgroup 0 guest-interface 0
  guest-ipaddress 192.168.2.2 netmask 255.255.255.0
 app-default-gateway 192.168.2.1 guest-interface 0
IP route on vrf looks good (adding only the relevant part):
      192.168.2.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.2.0/24 is directly connected, VirtualPortGroup0
L        192.168.2.1/32 is directly connected, VirtualPortGroup0
Also, the arp resolution was fine on the vrf:
Internet  192.168.2.2             1   <container mac address>  ARPA   VirtualPortGroup0
Here is some ping from the container. I see the same behavior towards all subnets in this vrf. Here is the ping to the vpg0:
ping 192.168.2.1
PING 192.168.2.1 (192.168.2.1): 56 data bytes
64 bytes from 192.168.2.1: seq=0 ttl=254 time=0.662 ms
64 bytes from 192.168.2.1: seq=1 ttl=254 time=0.826 ms
64 bytes from 192.168.2.1: seq=3 ttl=254 time=0.727 ms
64 bytes from 192.168.2.1: seq=5 ttl=254 time=0.631 ms
Since there is connectivity, but only every alternate packet is being dropped, I assume this is not an unsupported feature and could be either a simple missing/misconfiguration.
Has anyone managed to get a container networking connected to a customer vrf (or vlan) ? Is there some configuration that I am missing here.
balaji.bandi
I have tested long back with simple VLAN, not I have seen that ping Loss.(but it was not that lastest code).
Do you have any Control plane QoS enabled if so please check that and disabled and try. ?
Another question, Do you have other VLAN L3 interface have same ping Loss ?  (not the container tagged one ?)
BB
Thanks for your reply.
I disabled all the QoS config, but that did not seem to help.
One point to note - the loss is happening on the VirtualPortGroup when it is added to the vrf (everything seems to work fine on global)
Regarding VLAN, I am trying to use vrf rather than vlan.
 ip vrf forwarding D1 ip address 192.168.2.1 255.255.255.0
Were you using C9500 ? If so can you please let me know how you managed to run a container on vlan. I have containers working fine on vlan in C9300, but that had a special port named "AppGigabitEthernet" for containers that could be configured in trunk/access modes. However, C9500 seems to lack that feature.
