Can't Connect to IOx Local Manager - 15.6.3M2 - IR829
Justin Chin-You
Team, I'm all out of ideas on this one. Really not sure where to go, I've got IOx working on another IR829 no problems but this one is fighting me.
I followed this guide to setup the environment: https://communities.cisco.com/docs/DOC-60826
The only thing i didn't do was configure NAT since there is no requirement for me to connect this to a public network.
I'm unable to browse to the local manager. (https:.//192.168.1.100:8443)
After completing all the other steps:
IOx Host comes up as expected:
Customer-IR829#show iox host list detail
IOX Server is running. Process ID: 330
Count of hosts registered: 1
Host registered:
    IOX Server Address: FE80::FA0B:CBFF:FEAA:C80C; Port: 22222
    Link Local Address of Host: FE80::1FF:FE90:8B05
    IPV4 Address of Host:       192.168.1.100
    IPV6 Address of Host:       fe80::1ff:fe90:8b05
    Client Version:             0.4
    Session ID:                 2
    OS Nodename:                Customer-IR829-GOS-1
    Host Hardware Vendor:       Cisco Systems, Inc.
    Host Hardware Version:      1.0
    Host Card Type:             not implemented
    Host OS Version:            1.3.2.3
    OS status:                  RUNNING
    Interface Hardware Vendor:  None
    Interface Hardware Version: None
    Interface Card Type:        None
    Applications Registered:
        Count of applications registered by this host: 0
Unable to telnet into the Guest-OS
Customer-IR829#telnet 192.168.1.100 2070
Trying 192.168.1.100, 2070 ...
% Connection refused by remote host
Upgraded and Downgraded Software:
Customer-IR829#show ver
Cisco IOS Software, ir800 Software (ir800-UNIVERSALK9-M), Version 15.6(3)M2, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Wed 29-Mar-17 20:43 by prod_rel_team
ROM: Bootstrap program is IR800
Customer-IR829 uptime is 18 minutes
System returned to ROM by Firmware Upgrade at 21:50:51 UTC Mon Jun 19 2017
System image file is "flash:/ir800-universalk9-mz.SPA.156-3.M2"
Last reload reason: Reload Command
Confirmed Line settings:
line 1 2
transport input all
transport output all
stopbits 1
line 3
script dialer lte
no exec
transport preferred lat pad telnet rlogin lapb-ta mop udptn v120 ssh
transport input all
line 4
no activation-character
no exec
transport preferred none
transport input all
Anyone have any ideas why I can't pull up the local manager?
Justin
Justin Chin-You
Okay, for anyone else who has run into this issue....
1) I had to Reverse SSH into the GOS (in my case 192.168.1.100)
     a) Use the user/Pass you created for Priv 15
2) Check the services
GOS#monit summary
Cannot translate 'Customer-IR829-GOS-1' to FQDN name -- Temporary Failure in name resolution
The Monit daemon 5.14 uptime: 15h 58m
Process 'dmo'          Running
File 'product_id'        Accessible
File 'hwid'                 Accessible
File 'svcbr0'              Accessible
File 'ioxcaps'            Accessible
Process 'caf'            Not Monitored
<snip>
3) Perform steps to change PID in the caf process
     a) Release Notes: Cisco IOS Release 15.6(3)M2 - Release Notes for Cisco IR800 Industrial Integrated Services Routers and Cisco 1000 Series…
     b) Post on issue here: Re: Unable to start CAF on freshly installed IR809
4) Edit /etc/hosts file to include the hostname for the GOS (in my case Customer-IR829-GOS-1)
5) Restart the caf service
     a) GOS#monit start caf
7 Replies 7
Justin Chin-You
Just adding to this, if I do a packet capture and try to browse to the local manager I get a TCP RST.
Web Browser says "Connection Refused"
Hi Steve,
Thanks for the reply. I did see that note but for the workaround to work I need to be able to telnet to the Guest-OS and I'm not able to do that. I get a connection refused.
To access the Local Manager, you need to set the related PAT rules. Please see IR 8xx Platforms - IOx Docs
I'll give it a shot. Based on the instructions my understanding was that NAT/PAT is not required as my laptop is on the inside of the network and can directly reach the GuestOS.
The instructions also call out that I could use a public IP and not use NAT/PAT here.
Hi Steve,
FYI... No luck configuring NAT did not help.
Justin Chin-You
GOS#monit summary
<snip>
