How can I get access to https://devhub-docker.cisco.com/ui/login/
wellisonwester
Visitor
Hello everyone!
How can I get access to https://devhub-docker.cisco.com/ui/login/ I already have a cisco login but for this page it doesn't work.
I need to generate the token key https://devhub-docker.cisco.com/v2/
I'm following the cisco tutorial: https://developer.cisco.com/docs/iox/#!docker-images-and-packages-repository/overview
Can anyone help me?
Alexander Stevenson
Hi @wellisonwester,
I was able to login using the SAML SSO link at the bottom (I was already logged-in the developer.cisco.com)
I just wanted you to know the functionality does work an it is reachable. Perhaps there is an issue with your access privileges. Can anyone else confirm please?
Thanks for your help Alex,
I've tried this before but it didn't work.
I tried it again today and it didn't work.
See that I log in to developer.cisco.com and Jfrog doesn't work.
I think there is some permission missing for my account, but I don't know how to solve it.
Thanks again!
jamessmilleree
Community Member
Hi, If you're unable to access https://devhub-docker.cisco.com/ui/login/ and your Cisco login isn't working, here's a short solution- You can try accessing the website using a different web browser or clearing your browser's cache and cookies. Sometimes, browser-related issues can prevent access. Or you can try this- Please try to refer to the guide of https://developer.cisco.com/docs/iox/#!docker-images-and-packages-repository-msbi course . And please note the API key listed there is not new, it is renewed to some value else. You may sign-in the web to check the value.
Thanks and regards
Good morning! Thank you for your reply
I'm actually following this tutorial from the link below.
Just testing a PaaS application.
https://developer.cisco.com/docs/iox/#!tutorial-build-sample-paas-type-iox-app-using-docker-toolchain/tutorial-build-sample-paas-type-iox-app-using-docker-toolchain
But I can't follow this step:
FROM devhub-docker.cisco.com/iox-docker/ir800/base-rootfs:latest
I tested it in other browsers and there was no difference, I got the same message, incorrect password.
I also made a python application using docker on my laptop, I hope to generate the package for IOx, I don't know if it will work, when I upload it to local manager.
