Missing layer while installing iox app on IR1101-K9
martinReynier
Community Member
I am trying to install an iox app on the ir1101.
I build my docker,
I used "docker save" to get the .tar image neede in the package.yaml file.
I use an usb device to put the package in the ir1101 and when I lanch the command for installation I get an error like this:
Unable to extrackt docker rootfs <tarfile.TarFile object at 0x7fa165fe10> to /tmp/caf/tmpExtractdx_hf9uv/rootfs Error mandatory layer "some layer id".tar is missing
I checked, and the layer isnt missng in the rootfs drom docker save AND in the package.tar from ioxclient
Did somebody have a hint ?
martinReynier
Community Member
Here is the tar pkg i got
