IOx on Cisco 4451 - several questions on functionality
Okay, i'll try to make this clear as possible.  I've set up several open service containers successfully, now i'm trying to convert some of it to IOx if possible.  I know my VirtualPortGroup 0, 1 and 2 connections route properly out of my router since my open service containers function without issue.  Keep that in mind.
Relevant hardware information:
Cisco 4451-X running Amsterdam 17.2.1
NIM-HDD (20g partition)
Packaging Methods:
ioxclient on Linux 18.04 Server
Deploy Methods:
Currently through CLI - tried WebUI with same results
Platform information as I understand it:
From the Devnet platform information page it states that after 16.10 the supported application types are as follows:
VM, LXC, Docker
To make my explanation somewhat easier, I have attempted to deploy a ubuntu container using the instructions from this github page:  https://github.com/etychon/ubuntu-IOx-x86
I followed the instructions with the exception of the package.yaml file.
descriptor-schema-version: "2.5"
info:
  description: "Ubuntu Linux with SSHd. Login: root/root"
  version: "1.0"
  author-link: "http://www.cisco.com"
  author-name: "Cisco Systems"
app:
  cpuarch: "x86_64"
  type: docker
  resources:
    profile: custom
    cpu: "10000"
    disk: "10240"
    memory: "2048"
    network:
        interface-name: eth0
        ports:
            tcp:
              - 22
# Specify runtime and startup
  startup:
    rootfs: rootfs.tar
    target: ["/usr/sbin/sshd", "-D"]
I package all that up using ioxclient (same way as the instructions on the github page) and move it to the harddisk: and install, activate and start.
That all works.
The problem I run into is, I cannot SSH to it like i should be able to.
If i run the app-hosting session appid <name> I can drop in to the container.  SSH is listening on 0.0.0.0 port 22
I originally had it set up on Virtualportgroup2 - on that port group i could ping out to the internet, use apt-get to pull in different packages to verify openssh was working.
When i try to ssh into the container i get a "Connection Reset"
I've tried from various machines and the 4451 itself.
I poked around on the devnet site for a while and found a reference saying that only VirtualPortGroup0 is allowed.
VirtualPortGroup0 currently hosts a linux vm with plex.
sh run | beg virtual-service
virtual-service
 signing level unsigned
virtual-service PLEX
 vnic gateway VirtualPortGroup0
 activate
Current configuration : 145 bytes
interface VirtualPortGroup0
ip address 172.16.230.1 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
end
app-hosting appid UbuntIOx
app-vnic gateway1 virtualportgroup 0 guest-interface 0
app-default-gateway 172.16.230.1 guest-interface 0
end
sh app-hosting detail appid UbuntIOx
App id : UbuntIOx
Owner : iox
State : RUNNING
Application
Type : docker
Version : 1.0
Description : Ubuntu Linux with SSHd. Login: root/root
Path : harddisk:ubuntu20.tar
Activated profile name : custom
Resource reservation
Memory : 2048 MB
Disk : 10240 MB
CPU : 10000 units
VCPU : 1
Attached devices
Type Name Alias
serial/shell iox_console_shell serial0
serial/aux iox_console_aux serial1
serial/syslog iox_syslog serial2
serial/trace iox_trace serial3
Network interfaces
eth0:
MAC address : 52:54:dd:2e:19:59
IPv4 address : 172.16.230.3
Network name : VPG0
Here's an example of what happens when I drop into the docker session and try various commands:
app-hosting connect appid UbuntIOx session
# ifconfig
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 172.16.230.3  netmask 255.255.255.248  broadcast 172.16.230.7
        inet6 fe80::5054:ddff:fe2e:1959  prefixlen 64  scopeid 0x20<link>
        ether 52:54:dd:2e:19:59  txqueuelen 1000  (Ethernet)
        RX packets 159359  bytes 12627875 (12.6 MB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 130  bytes 11056 (11.0 KB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 0  bytes 0 (0.0 B)
        TX packets 0  bytes 0 (0.0 B)
# ping 172.16.230.1
PING 172.16.230.1 (172.16.230.1) 56(84) bytes of data.
64 bytes from 172.16.230.1: icmp_seq=1 ttl=255 time=0.300 ms
64 bytes from 172.16.230.1: icmp_seq=2 ttl=255 time=0.303 ms
64 bytes from 172.16.230.1: icmp_seq=3 ttl=255 time=0.274 ms
64 bytes from 172.16.230.1: icmp_seq=4 ttl=255 time=0.283 ms
^C
--- 172.16.230.1 ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3094ms
rtt min/avg/max/mdev = 0.274/0.290/0.303/0.012 ms
# ping 172.16.230.2
PING 172.16.230.2 (172.16.230.2) 56(84) bytes of data.
64 bytes from 172.16.230.2: icmp_seq=1 ttl=64 time=0.458 ms
64 bytes from 172.16.230.2: icmp_seq=2 ttl=64 time=0.376 ms
64 bytes from 172.16.230.2: icmp_seq=3 ttl=64 time=0.386 ms
64 bytes from 172.16.230.2: icmp_seq=4 ttl=64 time=0.408 ms
^C
--- 172.16.230.2 ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3053ms
rtt min/avg/max/mdev = 0.376/0.407/0.458/0.031 ms
# ping 8.8.8.8
ping: connect: Network is unreachable
# ping 67.2.217.255
172.16.230.2 is the plex server - i have dhcp set up and as I stated above the plex server works just fine.
outside interface:  Dialer2 67.2.217.255 YES IPCP up up
I'm perplexed to what the issue is here.
I've also set up guestshell to VPG0 and that also works fine, but that's not a docker type, so i wonder if there's some sort of incompatibility or I have to set up some extra route statement to communicate with CAF.  I don't know at this point.
Any assistance that could be given would be greatly appreciated!
FYI: I am not using the MGMT port on the 4451 at all.
