IR829 interface web
youssef.el-bourakkadi.1
Frequent Visitor
Frequent Visitor
I want to know if it is possible to configure IR829GW with a web interface, if yes how to proceed please?
balaji.bandi
Not that i am aware day 0 using GUI, but cli i can http server config, i belive this required basic config and enable http (this required some testing)
https://www.cisco.com/c/en/us/td/docs/routers/access/800/807/software/configuration/guide/b_IR807_config/b_IR807_config_chapter_011.html?bookSearch=true
BB
Flo Pachinger
Hey Youssef,
the IR829 is running classic IOS and an embedded Linux distro for the Cisco IOx edge compute framework.
Classic IOS does not yet support a web UI (IOS XE does), therefore you need to configure the device via CLI.
If you are looking to install IOx applications, you can do that via a web UI. More information on here: https://developer.cisco.com/docs/iox/#!ir-800-series-platform-information
