LoRa iU880B-usb data sending on IOx
andrei.voicu
Hello, I'm trying to simulate data sending over iU880B LoRa device (https://wireless-solutions.de/products/gateways/iu880b-usb.html) from IOx. Can someone help me on how can I do that?
Thanks!
Steve Zhang
Hi Andrei,
Basically the USB for IR8x9 IOx support the general serial interface or USB storage for the USB interface currently.
If you have software drivers and the LoRa stack implemented on its USB dongle hardware, you may use a generic serial interface for communication. Or if the USB dongle needs IOx software drivers and a LoRa stack, IOx does not support it yet. Hope it helps.
Steve
Steve Zhang
Hi Andrei,
Steve
