Message Queue not found on DOcker Filesystem IR829
abi_Cheetah
Frequent Visitor
Frequent Visitor
I have an Ubuntu based docker and I run an application inside it which uses posix queues. I found that Docker doesn not have mqueue in its file system. I wanted to know how to acquire the file system in /proc/sys/fs of the docker .
I did see the host machine (Guest OS) has the mqueue in its file system. I wanted to know whether we can avail the mqueue in the Docker .
Alexander Stevenson
I haven't seen an example of running mqueue specifically in Docker but I have see Message Queues used in Docker via RabbitMQ.
Please see these two resources (both are EXTERNAL to Cisco):
Hope this helps!
