"Opkg update" fails in LXC container
Kouji Yamanaka
Hey Community,
I'm investigating the creation of LXC type containers.
I operated according to "Docker Images and Packages Repository".
https://developer.cisco.com/docs/iox/#!docker-images-and-packages-repository
Accessing the repository using docker daemon
[Step.1:Login to the Cisco devhub using generic user credentials.]
<<CODE SNIPPET>>
$ docker login -u iox_docker.gen -p AKCp2WX2yZXhwiQXG2xZjHvnrov8HA2HkXZyH3Z46ErGNMDz1fHQKAMRCBbEvseLowd7BQ8S1 devhub-docker.cisco.com
WARNING: login credentials saved in /home/user/.dockercfg.
Login Succeeded
<<Execution result>>
Error response from daemon: Get https://devhub-docker.cisco.com/v2/: unauthorized: BAD_CREDENTIAL
<<QUESTION>>
Is the password changed?
Please tell me the correct password.
[Step.2:Pull the docker image based on the target architecture using 'docker pull' command.]
<<CODE SNIPPET>>
$ docker pull devhub-docker.cisco.com/iox-docker/ir800/base-rootfs
<omitted below>
Using default tag: latest
latest: Pulling from iox-docker/ir800/base-rootfs
c8e49009c524: Pull complete
Digest: sha256:f14bed751e384496ca40645c8221990bc1ab8fec6cae53b452ae09e2e91db0d4
Status: Downloaded newer image for devhub-docker.cisco.com/iox-docker/ir800/base-rootfs:latest
<<QUESTION>>
Login to devhub failed but 'docker pull' worked.
Are there any problems with this procedure?
[Step.3:Running the image]
<<CODE SNIPPET>>
$ docker run -it devhub-docker.cisco.com/iox-docker/ir800/base-rootfs /bin/sh
Unable to find image 'devhub-docker.cisco.com/iox-docker/ir800/base-rootfs:latest' locally
<omitted below>
<<QUESTION>>
no problem.
Because I pull the image in Step 2,
[Step.4:Update opkg package repository]
<<CODE SNIPPET>>
/ # opkg update
Downloading https://devhub.cisco.com/artifactory/IOx-Opkg/yocto-1.7.2/ir800/core2-64/Packages.gz.
Updated source 'packages'.
Downloading https://devhub.cisco.com/artifactory/IOx-Opkg/yocto-1.7.2/ir800/ir800_lxc/Packages.gz.
Updated source 'ir800_lxc'.
Downloading https://devhub.cisco.com/artifactory/IOx-Opkg/yocto-1.7.2/ir800/../all/Packages.gz.
Updated source 'all'.
Downloading https://devhub.cisco.com/artifactory/IOx-Opkg-alpha/yocto-1.7.2/ir800/core2-64/Packages.gz.
Updated source 'packages_delta'.
Downloading https://devhub.cisco.com/artifactory/IOx-Opkg-alpha/yocto-1.7.2/ir800/ir800_lxc/Packages.gz.
Updated source 'ir800_lxc_delta'.
Downloading https://devhub.cisco.com/artifactory/IOx-Opkg-alpha/yocto-1.7.2/ir800/../all/Packages.gz.
Updated source 'all_delta'.
/ # opkg update
Downloading https://devhub.cisco.com/artifactory/IOx-Opkg/yocto-2.1.1/ir800/core2-64/Packages.gz.
Downloading https://devhub.cisco.com/artifactory/IOx-Opkg/yocto-2.1.1/ir800/ir800_lxc/Packages.gz.
Downloading https://devhub.cisco.com/artifactory/IOx-Opkg/yocto-2.1.1/all/Packages.gz.
Downloading https://devhub.cisco.com/artifactory/IOx-Opkg-alpha/yocto-2.1.1/ir800/core2-64/Packages.gz.
Downloading https://devhub.cisco.com/artifactory/IOx-Opkg-alpha/yocto-2.1.1/ir800/ir800_lxc/Packages.gz.
Downloading https://devhub.cisco.com/artifactory/IOx-Opkg-alpha/yocto-2.1.1/all/Packages.gz.
Collected errors:
* opkg_validate_cached_file: Failed to download https://devhub.cisco.com/artifactory/IOx-Opkg/yocto-2.1.1/ir800/core2-64/Packages.gz headers: HTTP response code said error.
* opkg_validate_cached_file: Failed to download https://devhub.cisco.com/artifactory/IOx-Opkg/yocto-2.1.1/ir800/ir800_lxc/Packages.gz headers: HTTP response code said error.
* opkg_validate_cached_file: Failed to download https://devhub.cisco.com/artifactory/IOx-Opkg/yocto-2.1.1/all/Packages.gz headers: HTTP response code said error.
* opkg_validate_cached_file: Failed to download https://devhub.cisco.com/artifactory/IOx-Opkg-alpha/yocto-2.1.1/ir800/core2-64/Packages.gz headers: HTTP response code said error.
* opkg_validate_cached_file: Failed to download https://devhub.cisco.com/artifactory/IOx-Opkg-alpha/yocto-2.1.1/ir800/ir800_lxc/Packages.gz headers: HTTP response code said error.
* opkg_validate_cached_file: Failed to download https://devhub.cisco.com/artifactory/IOx-Opkg-alpha/yocto-2.1.1/all/Packages.gz headers: HTTP response code said error.
<<QUESTION>>
Have I affected by failing login to devhub at Step.1?
It seems that the password used in Step 1 differs from the password described in "opkg.conf" of the pull image,
but can it be different?
[[Setting up opkg.conf]]
/ # cat /etc/opkg/opkg.conf
# Must have one or more source entries of the form:
#   src <src-name> <source-url>
# and one or more destination entries of the form:
#   dest <dest-name> <target-path>
# where <src-name> and <dest-names> are identifiers that
# should match [a-zA-Z0-9._-]+, <source-url> should be a
# URL that points to a directory containing a Familiar
# Packages file, and <target-path> should be a directory
# that exists on the target system.
# Proxy Support
#option http_proxy http://proxy.tld:3128
#option ftp_proxy http://proxy.tld:3128
#option proxy_username <username>
#option proxy_password <password>
# Enable GPGME signature
# option check_signature 1
option http_auth iox_docker.gen:AKCp5bAif2Tzg1MtWAJbLoTXweosuqqSgSEyKApikowUq5sycevTsK7LcQ7EKLbzQFuyc9WCk
# Offline mode (for use in constructing flash images offline)
#option offline_root target
#src/gz base http://downloads.openwrt.org/snapshots/trunk/x86/64/packages/base/
#src/gz packages http://downloads.openwrt.org/snapshots/trunk/x86/64/packages/packages/
src/gz packages https://devhub.cisco.com/artifactory/IOx-Opkg/yocto-2.1.1/ir800/core2-64
src/gz ir800_lxc https://devhub.cisco.com/artifactory/IOx-Opkg/yocto-2.1.1/ir800/ir800_lxc
src/gz all https://devhub.cisco.com/artifactory/IOx-Opkg/yocto-2.1.1/all
src/gz packages_alpha https://devhub.cisco.com/artifactory/IOx-Opkg-alpha/yocto-2.1.1/ir800/core2-64
src/gz ir800_lxc_alpha https://devhub.cisco.com/artifactory/IOx-Opkg-alpha/yocto-2.1.1/ir800/ir800_lxc
src/gz all_alpha https://devhub.cisco.com/artifactory/IOx-Opkg-alpha/yocto-2.1.1/all
dest root /
[STEP.5:The docker base image to create a custom image.]
<<CODE SNIPPET>>
$ ls
cpp_app  Dockerfile
$ cat Dockerfile
FROM devhub-docker.cisco.com/iox-docker/ir800/base-rootfs
COPY cpp_app /opt/apps/
RUN opkg update
RUN opkg install libstdc++
$ docker build -t cpp-app .
Sending build context to Docker daemon  2.56 kB
Step 1/4 : FROM devhub-docker.cisco.com/iox-docker/ir800/base-rootfs
---> 4d39f5d04ab4
Step 2/4 : COPY cpp_app /opt/apps/
---> 38d9fa9c6adb
Removing intermediate container 746e8301fa7a
Step 3/4 : RUN opkg update
---> Running in 9003634832a3
---> 5bf91eac8d96
Removing intermediate container 9003634832a3
Step 4/4 : RUN opkg install libstdc++
---> Running in d5dfc986ae0f
Installing libstdc++6 (4.9.1-r0) on root.
Downloading https://devhub.cisco.com/artifactory/IOx-Opkg/yocto-1.7.2/ir800/core2-64/libstdc++6_4.9.1-r0_core2-64.ipk.
Installing libgcc1 (4.9.1-r0) on root.
Downloading https://devhub.cisco.com/artifactory/IOx-Opkg/yocto-1.7.2/ir800/core2-64/libgcc1_4.9.1-r0_core2-64.ipk.
Configuring libgcc1.
Configuring libstdc++6.
---> a70aaa99e63d
Removing intermediate container d5dfc986ae0f
Successfully built a70aaa99e63d
$ ls
cpp_app  docker-test
$ cat docker-test
RUN opkg update
Sending build context to Docker daemon   2.56kB
---> 5dc0d1ddffa1
---> 1cdf921f7a49
Removing intermediate container 186cafc268e3
---> Running in c726ef92d9fd
Collected errors:
The command '/bin/sh -c opkg update' returned a non-zero code: 6
<<QUESTION>>
==== Supplement ====
Since "apt-get update" succeeds in the execution environment, I think that there is no problem with the network.
$ sudo apt-get update
[sudo] password for yamanaka:
Get:1 http://security.ubuntu.com/ubuntu xenial-security InRelease [107 kB]
Hit:2 https://apt.dockerproject.org/repo ubuntu-xenial InRelease
Hit:3 http://us.archive.ubuntu.com/ubuntu xenial InRelease
Get:4 http://us.archive.ubuntu.com/ubuntu xenial-updates InRelease [109 kB]
Get:5 http://us.archive.ubuntu.com/ubuntu xenial-backports InRelease [107 kB]
Fetched 323 kB in 1s (177 kB/s)
Reading package lists... Done
Thank you.
Kouji
8 Replies 8
yawming
I happen to see someone asked similar question and the solution :
Hope this can address your issue too.
We have already identified this issue where anyone logged-in with the generic credential could change the API key and it will break the access to the devhub. Currently we are working on it and testing the open access to devhub repo where we could avoid this issue. Meanwhile as workaround can you add this line in the dockerfile before using opkg instructions:
RUN sed -i 's/\(option http_auth iox_docker.gen:\).*/\1AKCp5bAif2Tzg1MtWAJbLoTXweosuqqSgSEyKApikowUq5sycevTsK7LcQ7EKLbzQFuyc9WCk/' /etc/opkg/opkg.conf
Hi,yawchen
Thank you for your cooperation.
I tried the workaround I got taught, but I got an error.
Step 1/5 : FROM devhub-docker.cisco.com/iox-docker/ir800/base-rootfs
---> 5dc0d1ddffa1
Step 2/5 : COPY cpp_app /opt/apps/
---> 167cece90e7d
Removing intermediate container e4b395965182
Step 3/5 : RUN sed -i 's/\(option http_auth iox_docker.gen:\).*/\1AKCp5bAif2Tzg1MtWAJbLoTXweosuqqSgSEyKApikowUq5sycevTsK7LcQ7EKLbzQFuyc9WCk/' /etc/opkg/opkg.conf
---> Running in 254ff1e20651
---> c7f1a5190e68
Removing intermediate container 254ff1e20651
Step 4/5 : RUN opkg update
---> Running in b86044767315
Collected errors:
To be honest, I don't know which key to use can you please try the following if not working then I will ask subject matter expert for you.
RUN sed -i 's/\(option http_auth iox_docker.gen:\).*/\1AKCp5bAt1aQQR9L3dk4FP6QLDjd9XYhZLuhCLaHuwYnoGmDPLc584stTT6cWSeNdYavPR3wAV/' /etc/opkg/opkg.conf
please use the latest.
The API key was updated after that and currently active key is  “AKCp5bAt5nK9nJBeq1nFe3Ywntfokny8f1oHeTYpLrGCYG9iv9P3gkX9KFj6wzHcQoLkwP5Pa”
Hi,yawchen
I was able to build successfully.
I also found a way to check the current API - Key in the devhub web UI.
It is frightening for anyone to regenerate API-Key.
Thank you.
Kouji
Glad it works for you.
Face the same issue,how can I find the right API-key ? which relevant steps in https://developer.cisco.com/docs/iox/#!docker-images-and-packages-repository/overview should I follow.Thanks a lot
I just want to point out that the correct line in th Dockerfile has to be:
RUN sed -i 's/\(option http_auth iox_docker.gen:\).*/\option http_auth iox_docker.gen:AKCp5bAt5nK9nJBeq1nFe3Ywntfokny8f1oHeTYpLrGCYG9iv9P3gkX9KFj6wzHcQoLkwP5Pa/' /etc/opkg/opkg.conf
Note: If the API Key changes the above line has to be adjusted.
