Some problems on the application running on an IR829.
wellisonwester
Good afternoon, everyone!
I have this application running on an IR829.
I have some problems, I would like to know if you have already gone through this and if you can help me.
1 - I need to write the logs to the environment variable.
So that I can debug them.
2 - the python script is "crashing". within 20 to 30 minutes it crashes, doesn't display the logs in the .txt file and I have to stop and start the application to get it back.
On my laptop it runs without interruption.
Is there anything I can do to stop this from happening in IR?
Thank you very much!
### package.yaml ###
descriptor-schema-version: "2.0"
info:
  name: Copia arquivos para FTP
  description: Python Copy FTP Application
  version: "1.0"
  author-link: http://www.cisco.com
  author-name: Cisco Systems
app:
  type: paas
  resources:
    profile: c1.small
    disk: 100
    network:
        interface-name: eth0
        ports:
            tcp: [3330]
  startup:
    runtime: python
    runtime-version: 2.7.3
    target: app.py
### activation.json ###
    "resources": {
        "profile": "c1.small",
        "network": [{
            "interface-name": "eth0",
            "network-name": "iox-bridge0",
            "ipv4": {
              "dns": "192.168.100.1",
              "gateway": "192.168.100.1",
              "ip": "192.168.100.240",
              "mode": "static",
              "prefix": "24",
              "default": true
#### app.py #####
# -*- coding: utf-8 -*-
#!/usr/bin/python
import ftplib
import subprocess
import os
import time
from datetime import datetime, timedelta
from threading import Thread
import SimpleHTTPServer
import SocketServer
import threading
ftp_dest_path = "/Data/"
ftp_source_path = "/home/Datalogger/"
host = "192.168.0.45"
logdir = os.getenv("CAF_PERSISTENT_DIR")
if logdir is None:
    logdir = "."  # Caso a variável de ambiente não esteja definida, use o diretório atual como padrão
# Funcao para registrar mensagens em um arquivo de log
def log_message(message
    now = datetime.now()
    current_time = now.strftime("%Y-%m-%d %H:%M:%S")
    log_filename = "log.txt"
    log_filepath = os.path.join(logdir, log_filename)
    with open(log_filepath, "a") as log_file:
        log_file.write("%s - %s\n" % (current_time, message))
def clear_old_logs():
    if os.path.exists(log_filepath
        last_modified_time = datetime.fromtimestamp(os.path.getmtime(log_filepath))
        current_time = datetime.now()
        if (current_time - last_modified_time).days > 30:
            os.remove(log_filepath)
def check_icmp(host
    try:
        subprocess.check_output(["ping", "-c", "1", host])  # Usando -c no Linux
        return True
    except subprocess.CalledProcessError:
        return False
def connect_ftp(host, username, password
    print("Entrei na função para conectar no FTP")
    max_retries = 5
    retries = 0
    while retries < max_retries:
        try:
            ftp = ftplib.FTP(host, timeout=10)  # Adiciona um timeout de 10 segundos
            ftp.set_pasv(True)
            ftp.login(username, password)
            return ftp, None  # Retorna também None para o erro
        except ftplib.all_errors as e:
            retries += 1
            error_message = "FTP connection attempt {}/{} failed. Error: {}".format(retries, max_retries, str(e))
            log_message(error_message)
            print(error_message)
            try:
                ftp.quit()  # Tenta desconectar em caso de falha
            except:
                pass
            time.sleep(1)  # Espera um curto período antes de tentar reconexão
    return None, "Failed to establish FTP connection after {} attempts.".format(max_retries)
def disconnect_ftp(ftp
    try:
        ftp.sendcmd('PASV')  # Envia PASV antes de fechar a conexão
        ftp.quit()
    except Exception as e:
        error_message = "Error while disconnecting FTP: {}".format(str(e))
def collect_ftp_info(ftp
    ftp.cwd(ftp_source_path)  # Altera o diretório de trabalho para o diretório desejado
    items = ftp.nlst()
    files = [item for item in items if "." in item]  # Filtra apenas arquivos
    return files
def copy_file(source_ftp, dest_ftp, file
    try:
        print("Entrei na função de cópia")
        dest_file_path = os.path.join(ftp_dest_path, os.path.basename(file))
        source_file_path = os.path.join(ftp_source_path, os.path.basename(file))
        source_mod_time = source_ftp.sendcmd("MDTM " + file)
        try:
            dest_mod_time = dest_ftp.sendcmd("MDTM " + dest_file_path)
        except ftplib.error_perm:
            dest_mod_time = None  # Arquivo não existe no destino
        if dest_mod_time is None or source_mod_time > dest_mod_time:
            with open(file, "wb") as local_file:
                source_ftp.retrbinary("RETR " + file, local_file.write)
            with open(file, "rb") as local_file:
                try:
                    dest_ftp.storbinary("STOR " + dest_file_path, local_file)
                except ftplib.error_perm as e:
                    if "550" in str(e
                        print("Erro 550: Permissão negada. Movendo arquivo para diretório de arquivos corrompidos.")
                        log_message("Erro 550: Permissão negada para {}. Movendo arquivo para diretório de arquivos corrompidos.".format(file))
                        move_corrupted_file(file)
                        return True, None  # Continua com o próximo arquivo sem gerar erro
                    else:
                        print("Erro durante a cópia de arquivo FTP: {}".format(str(e)))
                        time.sleep(5)  # Aguarda antes de tentar novamente
                        return False, str(e)  # Tenta novamente
            os.remove(file)
            # Verifique o tamanho do arquivo no servidor de origem e no servidor de destino
            source_size = source_ftp.size(file)
            dest_size = dest_ftp.size(dest_file_path)
            print("Comparando arquivos: {} ({} bytes) vs {} ({} bytes)".format(
                file, source_size, dest_file_path, dest_size))
            if source_size == dest_size:
                # Se os tamanhos são iguais, o arquivo foi copiado corretamente
                bkp_file_path = os.path.join("/home/Datalogger/bkp/", os.path.basename(file))
                try:
                    source_ftp.rename(file, bkp_file_path)
                    print("Movendo arquivos já copiados")
                    if "550" in str(e
                        print("Erro 550: Não foi possível mover {}. Continuando...".format(file))
                        log_message("Erro 550: Não foi possível mover {}. Continuando...".format(file))
                        pass
                    else:
                        print("Erro ao mover arquivo FTP: {}".format(str(e)))
                message = "File %s copied successfully from source to destination and moved to /home/Datalogger/bkp." % file
                log_message(message)
                print(message)
            else:
                # Se os tamanhos são diferentes, move o arquivo corrompido
                print("Erro: Tamanhos diferentes. Movendo arquivo para diretório de arquivos corrompidos.")
                log_message("Erro: Tamanhos diferentes para {}. Movendo arquivo para diretório de arquivos corrompidos.".format(file))
        return True, None  # Retorna sucesso e None para o erro
def move_corrupted_file(file
    corrupted_dir = "/home/Datalogger/corrupted/"
    if not os.path.exists(corrupted_dir
        os.makedirs(corrupted_dir)
    corrupted_file_path = os.path.join(corrupted_dir, os.path.basename(file))
    os.rename(file, corrupted_file_path)
# Handler personalizado para o servidor HTTP
class MyHandler(SimpleHTTPServer.SimpleHTTPRequestHandler
    pass
def start_http_server():
    handler = MyHandler
    httpd = SocketServer.TCPServer(('0.0.0.0', 3330), handler)
    print("Server running on port 3330")
    httpd.serve_forever()
def create_log_file():
    log_file_path = os.path.join(logdir, "log.txt")
    with open(log_file_path, "w") as log_file:
        log_file.write("Initial log content.")
def test_icmp(host
    try:
        subprocess.run(["ping", "-c", "1", host], timeout=10, check=True)
        return True
        print("Teste ICMP falhou para o host: {}".format(host))
        log_message("Teste ICMP falhou para o host: {}".format(host))
        return False
    except subprocess.TimeoutExpired:
        print("Teste ICMP expirou para o host: {}".format(host))
        log_message("Teste ICMP expirou para o host: {}".format(host))
        return False
def start_ftp_operations():
    while True:
        try:
            clear_old_logs()
            ftp_dest_host = "192.168.0.45"
            ftp_dest_user = "User"
            ftp_dest_pass = "Password"
            ftp_source_host = "192.168.0.247"
            ftp_source_user = "User"
            ftp_source_pass = "Password"
            icmp_host_to_check = ftp_dest_host
            icmp_failures = 0
            ftp_dest_failures = 0
            ftp_source_failures = 0
            def ftp_operations(source_ftp, dest_ftp
                try:
                    while True:
                        if test_icmp(ftp_source_host) and test_icmp(ftp_dest_host
                            source_ftp, source_error = connect_ftp(ftp_source_host, ftp_username, ftp_password)
                            dest_ftp, dest_error = connect_ftp(ftp_dest_host, ftp_username, ftp_password)
                            if source_ftp and dest_ftp:
                                try:
                                    ftp_operations(source_ftp, dest_ftp)
                                finally:
                                    source_ftp.quit()
                                    dest_ftp.quit()
                            else:
                                log_message("Falha na conexão FTP. Source: {}. Dest: {}.".format(source_error, dest_error))
                        time.sleep(30)  # Aguarda 30 segundos antes de tentar novamente
                except KeyboardInterrupt:
                    print("Script interrompido pelo usuário.")
                    print("Erro no script: {}".format(str(e)))
                    log_message("Erro no script: {}".format(str(e)))
            def test_icmp(host
                try:
                    return True
                    return False
                    return False
            def ftp_operations_thread(source_host, source_user, source_pass, dest_host, dest_user, dest_pass, ftp_failures, log_prefix
                while True:
                    try:
                        if not check_icmp(dest_host
                            print("Entrei na funcao do teste ICMP")
                            ftp_failures += 1
                            mensagem = "{} Falha no teste ICMP ({} falhas). Tentando novamente em 1 segundo...".format(log_prefix, ftp_failures)
                            log_message(mensagem)
                            print(mensagem)
                            time.sleep(1)
                            continue
                        ftp_failures = 0
                        mensagem = "{} Teste ICMP bem-sucedido. Tentando conexão FTP...".format(log_prefix)
                        print(mensagem)
                        source_ftp, erro_source = connect_ftp(source_host, source_user, source_pass)
                        dest_ftp, erro_dest = connect_ftp(dest_host, dest_user, dest_pass)
                        if source_ftp is None or dest_ftp is None:
                            ftp_failures += 1
                            mensagem = "{} Falha na conexão FTP ({} falhas). Erro Source: {}. Erro Dest: {}".format(log_prefix, ftp_failures, erro_source, erro_dest)
                            print(mensagem)
                        else:
                            mensagem = "{} Conectado ao FTP.".format(log_prefix)
                            print(mensagem)
                        if source_ftp is not None and dest_ftp is not None:
                            ftp_failures = 0
                            try:
                                arquivos = collect_ftp_info(source_ftp)
                            except ftplib.error_temp as e:
                                if "425" in str(e
                                    print("{} Erro 425: Não é possível preparar para a conexão de dados. Tentando novamente em 1 segundo...".format(log_prefix))
                                    print("Arquivos" + arquivos)
                                    time.sleep(1)
                                    continue
                            mensagem = "{} Copiando arquivos...".format(log_prefix)
                            print(mensagem)
                            for arquivo in arquivos:
                                tentativas = 0
                                while tentativas < 3:  # Tenta até 3 vezes
                                    try:
                                        print(arquivos)
                                        sucesso, erro = copy_file(source_ftp, dest_ftp, arquivo)
                                        if not sucesso:
                                            mensagem = "{} Falha ao copiar {}. Erro: {}".format(log_prefix, arquivo, erro)
                                            print(mensagem)
                                        break
                                        if "425" in str(e
                                            time.sleep(1)
                                            tentativas += 1
                                            continue
                                        else:
                                            print("{} Erro temporário FTP: {}. Tentando novamente em 1 segundo...".format(log_prefix, str(e)))
                                            time.sleep(1)
                                            tentativas += 1
                                            continue
                            try:
                                disconnect_ftp(source_ftp)
                                disconnect_ftp(dest_ftp)
                                print("{} Erro ao encerrar as conexões FTP: {}".format(log_prefix, e))
                            mensagem = "{} Operações FTP concluídas.".format(log_prefix)
                            print(mensagem)
                        mensagem = "{} Fora do loop interno.".format(log_prefix)
                        print(mensagem)
                        print("Funçao Thread, aguarde 30 segundos...")
                        time.sleep(30)
                        print("{} Erro não tratado: {}. Tentando novamente em 1 segundo...".format(log_prefix, str(e)))
                        time.sleep(120)
            ftp_operations_thread(ftp_source_host, ftp_source_user, ftp_source_pass, ftp_dest_host, ftp_dest_user, ftp_dest_pass, ftp_dest_failures, "Destination")
            ftp_operations_thread(ftp_source_host, ftp_source_user, ftp_source_pass, ftp_dest_host, ftp_dest_user, ftp_dest_pass, ftp_source_failures, "Source")
            time.sleep(5)
            # Crie o arquivo log.txt inicial
            create_log_file()
            time.sleep(5)  # Aguarda 5 segundos antes de reiniciar
            print("Erro não tratado no loop principal: {}. Reiniciando em 5 segundos...".format(str(e)))
            time.sleep(5)
            # Inicie o servidor HTTP em uma thread separada
            http_server_thread = Thread(target=start_http_server)
            http_server_thread.start()
            # Espere que a thread do servidor HTTP termine
            http_server_thread.join()
if __name__ == "__main__":
0 Replies 0
