Unable to delete port mapping from IOx Local Manager
I have created TCP port mapping of application from IOx Local Manager. However, I don't see any option to delete it. The application is not running and it is in deployed state. Please let me know how to delete the port mapping.
Flo Pachinger
Please check your package.yaml file when you've created the application. There you can set for each protocol (TCP,UDP) a port mapping, in your case this should be 443. If you don't need it, delete/change it from there.
@Flo Pachinger - Thank you for the response. I have not created port mapping from package.yaml file. The port mapping was created from the iOX local manager. However, I cannot see any option to delete the port mapping in iOX local manager.
Flo Pachinger
Try to un-deploy and re-deploy. Then the mappings should be gone.
https://developer.cisco.com/docs/iox/#!application-development-concepts/application-development-concepts
