Unable to start IOx service on C819
Jamesits
I'm on a C819 running c800-universalk9_iox-mz.SPA.156-3.M5.bin trying to do some experiments on IOx.
All IOx-related config commands and show commands run very slowly and sometimes fail, while other config commands work very well. After configured everything according to the documentation, I'm unable to access IOx local manager.
I can ping IOx host IP from both the router and my computer, and I can access IOx host IP 443 port (though it replies a 404) but 8443 port is not open. Telnet to IOx host IP doesn't work. Tried reloading multiple times or iox reset, they didn't work.
What should I do to make it work?
System version:
iox-test#show ver
Cisco IOS Software, C800 Software (C800-UNIVERSALK9_IOX-M), Version 15.6(3)M5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Tue 31-Jul-18 08:25 by prod_rel_team
ROM: System Bootstrap, Version 15.2(2r)T1, RELEASE SOFTWARE (fc1)
iox-test uptime is 35 minutes
System returned to ROM by reload at 17:17:59 UTC Fri Jan 11 2019
System image file is "flash:c800-universalk9_iox-mz.SPA.156-3.M5.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
IOx status:
IOx Infrastructure Summary:
Services State : FAIL
Networking Configured : OK
IOS Network Reachable : OK
Host Infrastructure State : FAIL
System Information:
Build Date : Mon Dec 19 16:15:52 IST 2016
Version : cwan_mizuno_dev/218
Uptime : 0d 0h 40m 21s
Disk Space Usage : 50% (490MB)
Memory Usage : 41% (207MB)
CPU Utilization : 0%
Networking Information:
IP Address : 192.168.3.2
IP Gateway : 255.255.255.0
IP Netmask : 192.168.3.1
IOx Host Agent:
Debug Level : WARNING
IOx Processes State:
caf : Not Running
crond : Running
ioxhad : Running
libvirtd : Running
monit : Running
Config:
Current configuration : 2251 bytes
! Last configuration change at 17:46:11 UTC Fri Jan 11 2019
version 15.6
service internal
hostname iox-test
boot-start-marker
boot system flash:c800-universalk9_iox-mz.SPA.156-3.M5.bin
boot-end-marker
aqm-register-fnf
aaa new-model
aaa session-id common
ip inspect WAAS flush-timeout 10
ip cef
no ipv6 cef
license boot module c800 level advipservices
username cisco privilege 15 password 0 cisco
redundancy
notification-timer 120000
controller Cellular 0
lte gps enable
lte modem link-recovery rssi onset-threshold -110
lte modem link-recovery monitor-timer 20
lte modem link-recovery wait-timer 10
lte modem link-recovery debounce-count 6
interface Cellular0
no ip address
encapsulation slip
shutdown
interface Cellular1
no ip address
encapsulation slip
shutdown
interface Ethernet1
ip address 192.168.3.1 255.255.255.0
ip virtual-reassembly in
interface FastEthernet0
no ip address
shutdown
interface FastEthernet1
no ip address
shutdown
interface FastEthernet2
no ip address
shutdown
interface FastEthernet3
no ip address
shutdown
interface GigabitEthernet0
ip address dhcp
duplex auto
speed auto
interface Serial0
no ip address
shutdown
clock rate 2000000
interface Vlan1
no ip address
iox
host ip address 192.168.3.2 255.255.255.0
host ip default-gateway 192.168.3.1
ip forward-protocol nd
no ip http server
no ip http secure-server
ipv6 ioam timestamp
access-list 1 permit any
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
vstack
line con 0
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
stopbits 1
line 3
no exec
line 8
no exec
line vty 0 4
transport input all
scheduler allocate 20000 1000
end
5 Replies 5
balaji.bandi
IP Gateway : 255.255.255.0 <-- this is subnetmask
IP Netmask : 192.168.3.1 - <-- This is Gateway
check the IP address information you configured on the interface also.
BB
I think there is a bug for some IOx versions that gateway and netmask are displayed inverted. According to some thread in this forum, it is only a display issue.
I've checked the interface IP addresses. I can ping the IOx IP address from a host on Gi0.
I've got the same issue. Does anybody know how to fix it?
balaji.bandi
there was a bug as mentioned check the version and upgrade.,
BB
We use the latest version IOS supporting IOX feature for 819.
Device Information:
- Device Type: IOS
- Model: C819G-4G-GA-K9
- Version: 15.6(3)M9
#do sh ver | s Ver
Cisco IOS Software, C800 Software (C800-UNIVERSALK9_IOX-M), Version 15.6(3)M9, RELEASE SOFTWARE (fc2)
Could you get the reference to the bug id?
