Run simple nginx on IR510 error
rod.leon
Visitor
I tried to run a simple nginx default server on IR510 but I can't start it.
  • ioxclient version 1.12.1.0 (On my Ubuntu 20.04 development machine)
Here the steps
  1. OK. Create the Dockerfile
    FROM arm32v7/nginx
    EXPOSE 80
    # Commands and test:
    # docker build -t ir510/nginx_test .
    # docker run --rm --name nt1 ir510/nginx_test
  2. Ok. ioxclient Package the Docker image (armv7/nginx)
    ioxclient docker package ir510/nginx_test .
  3. Ok.ioxclient Install the app on device IR510
    ioxclient app install app_nginx package.tar
  4. Ok.ioxclient Activate the app
    ioxclient app activate --payload activation.json app_nginx
  5. Fail.ioxclient Run the app
    ioxclient app start app_nginx
Error message:
 "description": "",
 "errorcode": -1014,
 "message": "Error while changing app state"
package.yaml content
descriptor-schema-version: "2.7"
info:
  version: 0.1
app:
  cpuarch: "armv7l"
  type: docker
  resources:
    cpu: "400"
    memory: "128"
    network:
    - interface-name: eth0
      ports:
        tcp:
        - "8010"
    profile: custom
  startup:
    rootfs: rootfs.tar
    target:
    - nginx
activation.json
    "resources": {
        "profile": "c1.tiny",
        "network": [{
            "interface-name": "eth0",
            "network-name": "iox-nat0",
            "port_map": {
                "mode": "auto",
                "tcp": {
                    "8010": "8010"
I don't find any information about to solve this problem.
rod.leon
Visitor
Finally solved. It was architecture issue, the original Dockerfile for this nginx is on arm64, so I changed to arm32v7 and that works. For this I built the dockerfile using docker buildx tool, Raspberry Pi can builds ARMs too.
rod.leon
Visitor
