Reason: 5.3.0 - Other mail system problem ('542'
aangster1
I have one Ironport C370 and when I send a message to an address I have this response
bounced by destination server. Reason: 5.3.0 - Other mail system problem ('542', ['5.7.1 Spiked: templates/60cde3022cf2c937.1.0.419.2522.2820.07090306040200..1/10'])
this recipient correctly receives these emails.
By performing tests still to the same destination but with a different address from our area I saw it functioned.
Robert Sherwin
You would need to check directly with the recipient end as to why they are denying your connection.
5.3.0 --->
Mail system status
       X.3.0   Other or undefined mail system status
          The destination system exists and normally accepts mail, but
          something about the system has caused the generation of this
          DSN.
The '542' = Bad Connection
5.7.1 always means there is a permanent failure of "Delivery not authorized, message refused"
5.7.1   Delivery not authorized, message refused
          The sender is not authorized to send to the destination.
          This can be the result of per-host or per-recipient
          filtering.  This memo does not discuss the merits of any
          such filtering, but provides a mechanism to report such.
          This is useful only as a permanent error.
Hope this helps!
-Robert
(*If you have received the answer to your original question, and found this helpful/correct - please mark the question as answered, and be sure to leave a rating to reflect!)
Robert Sherwin
5.3.0 --->
Mail system status
          DSN.
Hope this helps!
-Robert
Thank you for your help. the problem actually came from distand server refused our message. the problem is resolut. is there a document that allows referencer the error code ironport?
