Reset connection whenever Max. Recipients Per Message exceeds threshold
nickliako
Dear all,
I am very well aware of the fact that whenever a sending MTA attempts to deliver a message on Cisco ESA that exceeds the threshold of "Max. Recipients Per Message" which defaults to 50, then it receives a "452 #4.5.3 Too many recipients."
However the message gets finally sent to Max. Recipients Per Message  and then the sending MTA attempts further connections towards ESA in order to deliver the same message to the rest of the recipients.
Is it feasible to instruct ESA so that he resets the connection whenever he sends a  "452 #4.5.3 Too many recipients." error code ?
Thanks in advance
daachary
The counter resets itself every hour, currently doesn't have an option to reset it using conditions.
The sender will anyways retry delivery as per their bounce profile.
Dayananda Acharya
