sender spoof security problems
5aaaaaaaa11
Community Member
telneting to Ironport external address on port 25,HELO and I am able to send mail to Success。
For example: mail from:[email protected]   rcpt to: [email protected]
Or mail from:[email protected]  rcpt to: [email protected]
This is a huge security hole, but I dont know how to fix it.
Jrod
Community Member
Try the ESA technotes:http://www.cisco.com/c/en/us/support/security/email-security-appliance/products-tech-notes-list.html
ESA Spoofed Mail Filtering
http://www.cisco.com/c/en/us/support/docs/security/email-security-appliance/117796-problemsolution-esa-00.html
Mathew Huynh
This would be seen as normal port 25 traffic for SMTP communication if you did a port 25 connection.
Spoofing can be managed with the article Jared has high-lighted.
Also it is suggested to enable LDAP recipient validation to further protect your domain from emails going to senders which do not exist in your domain.
I would advise to go to the Online Help Guide on your ESA (GUI > Help and Support > Online Help)
Look for LDAP accept -- the guide will provide detailed information on this function and deployment for added security.
Matthew
