AMP for Endpoints - Client Upgrade deployment need help
sakhigbe
We purchased and installed AMP for endpoints in August 2018 for 500 computers ( had a summer student manually install), I am planning to upgrade and we currently don't have SCCM, has anyone deployed via Login script or Windows group policy and if you can you please share how this was done.
I have searched Cisco questions but no MSI has been released.
6 Replies 6
balaji.bandi
Look at AMP Endpoint Deployment Strategy  :
https://docs.amp.cisco.com/en/A4E/AMP%20for%20Endpoints%20Deployment%20Strategy.pdf
BB
Orlith
If you plan to upgrade why don't you use your amp policy to do so ? Just tell the policy you want to upgrade to the xxx version and set the time frame.
Upgrading by running the msi or the exe file directly won't work (at least with the exe file it is failing) as the previous version needs to be uninstalled first.
Hello, Will you be able to provide some information on where in the policy this is done ?
Much appreciated.
Hello
There :
EDIT:  Please ignore.  Didn't realize this was a response to a previous question.
Could you please clarify what the issue is?  It is unclear from the screenshot.
Matt
