Product updates for Cisco AMP connectors
vaibhav58
Hi Guys,
What setting should be there for the connectors to get auto updated.
My computer is on version 5.1.13 and we have below setting :
Product Version -  none
So do  we manually update all workstations? Since i see 6.0.5 is the latest and we are still on old
thanks in advance!!
Vaibhav
21 Replies 21
Correct 7.0 to 7.1.5 shouldnt need a reboot
If you go from 7.0.5 to the latest, you should not need a reboot.  As I mentioned, there may be some edge cases where a reboot is required but those should be rare and if you hit one, please let us know so we can get it fixed going forward.
Matt
for version upgrades 6.x to 7.x :
WHY does the product uninstall and sit unprotected until the reboot happens?  Seems to be a big development flaw.  The product should download the update, recommend the reboot, and sit protected with 6.x ... once the reboot is initiated conduct the upgrade and reboot.  problem solved! ... Makes 0 sense to uninstall the moment the update is received.
As is I do not know when i can upgrade to 7.x ... I cant leave the majority of my infrastructure unprotected waiting for people to reboot, and I cannot forcefully reboot everything in the environment.  I have been upgrading manually and very very slowly.
TianLiu98138
https://www.cisco.com/c/en/us/support/security/fireamp-endpoints/tsd-products-support-install-and-upgrade-technotes-list.html
can check above link for the official suggestion of which version upgrade needs reboot as well as OS compatibility.
Hello @TianLiu98138,
improvement for "No Reboot Updates" are included in the latest 7.x connector version.
  • Upgrading from versions <7.x to Version 7.x needs an Endpoint Reboot.
Regarding OS compatibility, are you looking for a specific OS version support?
Greetings,
Thorsten
Hello @Troja007 ,
I just find the link so share it with others.
No need for the compatibility support currently, Thanks for asking.
Tian
Troja007
i assume this discussion can be marked as resolved, as needed reboots after connector upgrades haven been solved a longer time ago.
Greetings, Thorsten
