Sponsored captive portal for wired guest authentication
juanfaure
I have seen this ISE reference for guest authentication & ISE:
https://community.cisco.com/t5/security-documents/ise-guest-access-deployment-guide/ta-p/3640475
, but i am still unsure if wired guest users can be redirected to a Sponsor Captive Portal using ISE (all examples i have seen are for wireless), can anyone inform about it?
Just in case if it is possible, layer 2 connectivity between wired guest vlan and ISE is required for the redirection?
Kind Regards,
Juan
balaji.bandi
check this may help for Wired client (most works the same way wireless and wired)
https://community.cisco.com/t5/network-access-control/ise-wired-captive-portal/td-p/2563656
https://integratingit.wordpress.com/2020/01/19/ise-guest-access/
BB
Navigate to Configure > Security > Access Control > Authentication Rules and click Enabled for HTTPS/HTTP Authentication page next to Captive Portal to select the feature. Users who match the rule are redirected to the new web portal authentication page.  My Ascension
