PfR true load-balancing for C1111-8P
im_skennedy
Please help with the configuration and errors I'm getting when attempting to configure:
c1111#configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
c1111(config)#interface GigabitEthernet0/0/1
c1111(config-if)#no standby 1 ip 192.168.1.254
c1111(config-if)#exit
c1111(config)#interface GigabitEthernet0/0/0
c1111(config-if)#description WAN Interface 1
c1111(config-if)#no shutdown
c1111(config-if)#ip address 192.168.1.201 255.255.255.0
c1111(config-if)#ip nat outside
c1111(config-if)#standby 1 ip 192.168.1.254
c1111(config-if)#standby 1 priority 110
c1111(config-if)#standby 1 preempt
c1111(config-if)#negotiation auto
c1111(config-if)#description WAN Interface 2
c1111(config-if)#ip address 10.1.2.2 255.255.255.0
% Address 192.168.1.254 in group 1 - interface GigabitEthernet0/0/0
c1111(config)#no ip route 0.0.0.0 0.0.0.0 10.1.2.1
%No matching route to delete
c1111(config)#ip route 0.0.0.0 0.0.0.0 192.168.1.1
c1111(config)#route-map PBR-WAN1 permit 10
c1111(config-route-map)#match ip address LAN_IN
c1111(config-route-map)#set ip next-hop 192.168.1.1!
c1111(config-route-map)#route-map PBR-WAN2 permit 10
c1111(config-route-map)#set ip next-hop 10.1.2.1!
c1111(config-route-map)#interface GigabitEthernet0/0/0
c1111(config-if)#ip policy route-map PBR-LIST-1
c1111(config-if)#exit!
c1111(config-if)#ip policy route-map PBR-LIST-2
c1111(config)#route-map list PBR-LIST-1
% Invalid input detected at '^' marker.
c1111(config)#set weight 2
c1111(config)#route-map PBR-WAN1!
c1111(config-route-map)#route-map list PBR-LIST-2
c1111(config)#set weight 1
c1111(config)#route-map PBR-WAN2!
c1111(config-route-map)#ip access-list extended LAN_IN
c1111(config-ext-nacl)#permit tcp any any eq www
c1111(config-ext-nacl)#permit tcp any any eq 443
c1111(config-ext-nacl)#permit icmp any any
c1111(config-ext-nacl)#permit tcp any any eq 22
c1111(config-ext-nacl)#deny ip any any!
c1111(config-ext-nacl)#end
c1111#
*Feb 13 21:57:59.607: %SYS-5-CONFIG_I: Configured from console by console
c1111#
c1111#
c1111#
sh ver | i IOS
Cisco IOS XE Software, Version 16.09.08
Cisco IOS Software [Fuji], ISR Software (ARMV8EB_LINUX_IOSD-UNIVERSALK9_IAS-M), Version 16.9.8, RELEASE SOFTWARE (fc4)
Cisco IOS-XE software, Copyright (c) 2005-2021 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
ROM: IOS-XE ROMMON
c1111#
c1111#
c1111#
c1111#sh run b
Building configuration...
Current configuration : 3195 bytes
! Last configuration change at 21:57:59 UTC Thu Feb 13 2025
version 16.9
platform qfp utilization monitor load 80
platform punt-keepalive disable-kernel-core
hostname c1111
boot-start-marker
boot-end-marker
logging buffered 20000
no aaa new-model
ip name-server 8.8.8.8 8.8.4.4
ip domain name home.local
ip dhcp excluded-address 192.168.10.1 192.168.10.10
ip dhcp pool LAN_DHCP
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
dns-server 8.8.8.8 8.8.4.4
login on-success log
subscriber templating
crypto pki trustpoint TP-self-signed-846397863
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-846397863
revocation-check none
rsakeypair TP-self-signed-846397863
crypto pki certificate chain TP-self-signed-846397863
certificate self-signed 01
diagnostic bootup level minimal
redundancy
mode none
vlan internal allocation policy ascending
ip nat outside
standby 1 preempt
negotiation auto
ip nat outside
ip access-group LAN_IN in
standby 1 preempt
negotiation auto
interface GigabitEthernet0/1/0
interface GigabitEthernet0/1/1
switchport access vlan 10
switchport mode access
spanning-tree portfast
interface GigabitEthernet0/1/2
interface GigabitEthernet0/1/3
interface GigabitEthernet0/1/4
interface GigabitEthernet0/1/5
interface GigabitEthernet0/1/6
interface GigabitEthernet0/1/7
interface Vlan1
no ip address
interface Vlan10
description LAN Interface
ip address 192.168.10.1 255.255.255.0
ip nat inside
no autostate
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http client source-interface GigabitEthernet0/0/0
ip tftp source-interface GigabitEthernet0/0/0
ip nat inside source list NAT_ACL interface GigabitEthernet0/0/1 overload
ip route 0.0.0.0 0.0.0.0 10.1.2.100
ip ssh version 2
permit icmp any any
permit ip any any
permit tcp any any eq domain
permit udp any any eq domain
deny ip any any
ip access-list extended NAT_ACL
permit ip 192.168.10.0 0.0.0.255 any
route-map PBR-WAN1! permit 10
route-map PBR-WAN2! permit 10
control-plane
line con 0
transport input none
stopbits 1
line vty 0 4
login local
transport input ssh
end
c1111#$
c1111#
c1111#
0 Replies 0
